Rubbermaid Lawn cart wheels
   / Rubbermaid Lawn cart wheels #1
tld
Boston, GA
JD 2025r
I have a Rubbermaid lawn cart that is 8 yrs old or so but in good shape. they currently cost about 250 new.
Problem is that the metal wheel rims are rusting and tires will not hold air. rust is in about the place water would pool up at the lip of the rim. Looking on the internet, Rubbermaid replacement is $32 to $45. Seems as if there should be a cheaper way to do this. Tires are still good. Tires are Kenda 4.80/4.00-8 and wheel has a 1 inch bore.
Any ideas?
   / Rubbermaid Lawn cart wheels #3
Maybe call a local bicycle shop to see if they can help. Also have seen some discussion on using expansion foam to fill all sorts of different tires- although it doesn't cushion the ride as well.
:2cents:
   / Rubbermaid Lawn cart wheels #4
exact same situation as first question...have older Rubbermaid trailer that needs wheels replaced.
   / Rubbermaid Lawn cart wheels #5
Take a look at Harbor Freight. They have a good assortment of wheels that should work for you.
Eddie
   / Rubbermaid Lawn cart wheels #6
Tractor Supply also might have wheels that you can use
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
1779 (A51248)
1779 (A51248)
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
2008 FORD F150 XL TRITON TRUCK (A54756)
2008 FORD F150 XL...
