Rust around fuel tank neck
   / Rust around fuel tank neck #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
I have a 2012 model John Deere 5093E. There is significant light rust around the filler neck, chain that attaches to the screw on fuel cap and a small spring in the cap..Any idea what could account for this?
   / Rust around fuel tank neck #2
I would assume it has a plastic tank. It is common to get rust around the filler neck on older metal tanks from water in fuel and just plain ole humidity . If it is plastic I would say it algae that's accumulating
Yes the tank is plastic..The rust is already somewhat pitted and the tractor is only a 2012 model..Is there any way to keep it from getting worse?
   / Rust around fuel tank neck #4
plastic does not rust , It has to be something else
The tank is plastic. The filler neck, chain and spring are metal
thnks
   / Rust around fuel tank neck #9
I concur, it's condensation from a partially full fuel tank, it happens a lot on older tractors, I pulled a fuel tank off my dad's 1950 Case SC that sat for 20 or so years, the top of the metal tank had 4-5 holes in it big enough that I could stick my finger in.
Only way to stop or slow it down is keep the tank full all the time but the neck would be more tricky.
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
GRAIN BIN - APPROX. 14' ACROSS (A52708)
GRAIN BIN -...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
