Rusted Gas Tank Repair and Motor Mounts
   / Rusted Gas Tank Repair and Motor Mounts #11
I agree with sand blast at least or Build New. I had a similar situation and building new was less time consuming with all things considered. Good Luck.
   / Rusted Gas Tank Repair and Motor Mounts #13
   / Rusted Gas Tank Repair and Motor Mounts #14
About 4 years ago I repaired and coated an old tractor gas tank with Bill Hirsch tank sealer. Haven't had any problem, and I use ethanol gas.
I've been using citric acid to remove rust lately. It works real well if you're a little patient. There are videos on YouTube about it.
   / Rusted Gas Tank Repair and Motor Mounts #17
Why not buy a new tank? Unless you want something to weld up.
   / Rusted Gas Tank Repair and Motor Mounts #18
   / Rusted Gas Tank Repair and Motor Mounts #19
Shield Arc - Thank you. By the way, I like the industrial "art deco" design of your mig welders. Much better looking than the modern box with knobs look.
John
   / Rusted Gas Tank Repair and Motor Mounts #20
The red stuff is what we used on old heavy equipment. Better operators then equipment fixers. Stuff worked where we tried it. Kept the diesel where it was put.
New/Unused CFG Industrial YSRT14 Min Skid Steer (A54865)
New/Unused CFG...
2001 International 3800 DT466E (A53314)
2001 International...
Northern AG Sprayer (A53314)
Northern AG...
Detroit Hydraulic Power Unit (A53316)
Detroit Hydraulic...
golf cart (A55758)
golf cart (A55758)
2013 Infiniti M37 Sedan (A55758)
2013 Infiniti M37...
