Rustic Fireplace Mantle
   / Rustic Fireplace Mantle #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
We are switching out our wood stove(putting it in the basment to heat down there), for a nice looking LP jotul stove.
We will be putting the stove in our great room(where we need to heat not the mudroom where the wood stove is now).
We were brainstorming what we can do and its a 6' piece of wall (knotty pine) and coming towards you a 3' piece of wall(corner area)(I will post pics as soon as my wife come home with the camera).(came home before I was done typing).
I have been doing fieldstone all summer, so what is a bit more.
We will do 60'' of fieldstone behind the stove (on cement board backer). (i will be picking out 1/4 max thick pieces for it).
We also want a live edge mantle, (i have a granburg chainsaw mill, and Love the Idea of making my own mantle).
It will be 6' long about 6'' thick and most are I think 9'' wide. 60'' from the floor.
I have two cement corbels with rebar and a bar (see pics) to hang them. but they are heavy (the rebar is imbeaded in them, with the bar welded to the rebar.they are 6'' wide at the widest by 9'' tall.
My question is
1. What the heck do I use to hold these to the wall I am really worried about the weight.
Any suggestions on my idea, also live or dead tree? I have an dead elms (tough as nails to saw) on our property, or I can cut any other hardwood, and have hemlock also.
http://www.appalachianwoods.com/furniture/antique_wood_mantel.htm
is similar to what we want to do.
   / Rustic Fireplace Mantle #2
Is that the best place for it? It looks a little jamed up, like its in a corner, between that window and that tiny wall. Do you not have a longer wall that you could put in on toward the middle of the room.
""between that window and that tiny wall""Thats actually of two sets of double doors heading to our deck. We also wish the previous owner, builder planned the layout better. The stove has to go there because then we can move the heat to the back bedrooms easier. Its really the only option we have for placing the stove.
We have that space, two sets of double doors then the same amount of space on the other side where our tv is. Those doors just take up so much space. So with our furniture and kitchen table and kiddo toys there are only so many places on an outside wall that we can place the stove.
(It is 6' of wall, then 6 foot of door, 6'' and then 6 foot of door and 6' of wall where the tv is.)
The smaller wall coming towards us on the right hand side seperates the great room(where the stove will go) with the mud room, you can see it in the stone pictures.
   / Rustic Fireplace Mantle #4
Hang the backer on the wall with lags long enough to reach the studs, or very heavy wood screws. The mantle will mostly sit on the fieldstone, but install long screws at a 45degree angle clear into the studs. Recess the screw heads and drive dowels into the holes, then cope the dowels off flush with the mantle.
In that tight a space, be sure to get a zero clearance stove and chimney.
   / Rustic Fireplace Mantle #5
The mason that built the chimney for us also put up a brick hearth inside for a wood stove. I insulated the stud bays behind the hearth with mineral wool and put up 5/8 inch fire rated sheetrock over the studs. The mason layed the brick up using wall ties to tie it to the studs. He used cored brick and anchored the first course to the floor with a flat bar and some lags. He left a 2 inch air space between the brick and the sheetrock. I used ceramic tile over dura-rock on the floor around the hearth.
   / Rustic Fireplace Mantle #6
Have you checked Jotul's clearance requirements for the stove you are looking at? Our Jotul is a wood burner and I don't think that setting would meet the setback requirements. May well be fine for an LP stove but the insurance companies can get very strict when it comes to stoves meeting code requirements.
MarkV
The jotuls clearance requirements for the lp stove are 2'' from the top, and it can sit on a hardwood floor,2'' to the back and 3'' to the sides.
Jotul GF 600 DV II Firelight Gas Stove
Rear: 2” (51 mm) from Rear Shroud
Ceiling: 30” (762 mm) from Stove Top
Corner: 3” (76 mm) from Stove Top
Sides: 3” (76 mm) from Stove Top
Minimum Clearances from the Vent Pipe
to Combustibles:
Horizontal Run:
Off the top of the pipe - 2” (51 mm)
Off the sides and bottom - 1” (25 mm)
Vertical Run:
All sides 1” (25 mm)
   / Rustic Fireplace Mantle #8
Sounds like you are good to go. It has been a long time but I remember much bigger clearances for mine when we did it. May want to watch those curtains though.
MarkV
   / Rustic Fireplace Mantle #9
Since you have knotty pine in the room already you may want to consider using that for the mantle as well. It sounds like you want to cut your own mantle from trees on your property. While it is possible, you must season it before you use it (which takes a long time for 6" lumber). Otherwise it will crack, split, shrink and do other bad things while it dries out in the house. You may be better off purchasing the mantle from a lumber dealer. Be sure it is kiln dried and they know what the application is. My neighbor did a mantle like you plan and still had problems with it splitting - since he'd hired it done, they came out and replaced it. What you are planning makes for a beautiful mantle!
   / Rustic Fireplace Mantle #10
I am going to make a mantle out of Oak, possibly also for the side columns. You may have to do what I am, I have several Oaks down and will let them finish out to one year, that will give me time to find or make a chainsaw mill for mostly just this little job.
I think a natural finish to the outside would be nice, any curvature to the original wood with knots or whatever, but naturally flat to the wall.
I think yours will look sharp with the rock. Have you considered using those big heavy ones for a hearth, or possibly a wood rack? then you may be able to avoid the "attaching to the wall" thing. Just a thought.
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
