S373D 3 point relief valve location?
   / S373D 3 point relief valve location? #1
Ehanson
Kamloops, B.C.
S373-D
Any one checked, shimmed the relief vale of the 3 point hydraulic pressure, and where is it located?
Thank you,
   / S373D 3 point relief valve location? #2
Looking at my manual, it appears to be inside the case as part of the control valve. I've never had mine off or had to adjust it. Book says not to fool with it unless a facility for measuring oil pressure is available.
OK, What I should do is take a pressure reading when the lift is in relief and see what is there.
Does the manual state a pressure the system has.
40ft Sea Container (A52384)
40ft Sea Container...
2014 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2014 Ford F-350...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
Miles read : 112,969 (A50323)
Miles read ...
Two Pairs of 8ft Fork Extensions (A55787)
Two Pairs of 8ft...
