SA, Single Action and DA, Double Action
   / SA, Single Action and DA, Double Action #1
AKKAMAAN
Port Angeles WA
Since SA and DA cylinders are a pretty common subject, I want to make this comment....
Some SA cylinders can look like a DA cylinder with two ports, but rod side port is always connected to return or straight to tank. Even if rod side is connected to the Control Valve port, there can be a spool SA valve spool, that makes the cylinder SA.
SA or DA is best determined by checking if there is "power down" or not.
   / SA, Single Action and DA, Double Action #2
Is that to drain away any 'leak by' pass the piston seals ?
With the piston side port piped to tank to do the same as above ?
Yes...
If cylinder is a SA that's plumbed on a "DA" cylinder, the rod side can either be air vented with a filter fitting in the port, or hydr-vented with a hose.
I always prefer hydr-vented because it takes care of oil that by-passes the piston seal, and also keep air moist out of the cylinder.
Sorry Willl, I do not know what you mean here...."piston side"= capped or rod side??
See if I can find an example of a SA spool .....
   / SA, Single Action and DA, Double Action #4
My bad,,,capped side.
It be just the opposite of one piped in the first example.
here are two drawing showing spool design for airvented alt hydr vented connected to CV work port...
This one looks like a DA connected cylinder but is actually SA, due to the spool design...
   / SA, Single Action and DA, Double Action #6
More questions,,,,
In your first example (OP), port C is plumbed to a SA output spool valve port and port R is plumbed to; return port on valve (1), or tank return (2), or vented to atmosphere(3).
Second example sounds just like the first except ports on cylinder are swapped. Correct ?
(1) If it's a SA spool valve, would there even be a return port on the valve ?
(2) If plumbed to tank (return), would it not 'suck' tank oil back to cylinder during retract mode ?
(3) Vented to air,,,like you said,,,moisture,,, but on a setup like a snow plow SA angle cylinders, you have no other choice but to vent to atmosphere. Correct ?
(4) Speaking of snow plows w/ SA cylinders, and more directly the dual SA angle cylinders, what's the correct plumbing ?, must it only be done with only a SA or DA spool valve ?
(5) Is there a difference between SA piston seals compared to DA ? (one would think so)
((sorry for all the ?'s, SA cylinders and spool valves have been a little cloudy for me.))
   / SA, Single Action and DA, Double Action #7
My questions are not limited towards AKKAMAAN specifically.
I'm not shy, I'll learn off anybody. :D
Thats Right!
Thats right too, but I did not intend to swap ports, that came with the deal, "stealing" the drawing from Prince...LOL
Is I showed on my TWO (2) drawing, there can be two (2) different kinds of SA spools, one for PLUGGED PORT, and one for OPEN PORT (connected to rod side)
You got it!! Thats right!:thumbsup:
(3) Vented to air,,,like you said,,,moisture,,, but on a setup like a snow plow SA angle cylinders, you have no other choice but to vent to atmosphere. Correct ? If there is a port, you can plumb a low pressure line to return or tank (below oil level)
(4) Speaking of snow plows w/ SA cylinders, and more directly the dual SA angle cylinders, what's the correct plumbing ?, must it only be done with only a SA or DA spool valve?
Anything simple and functional is most likely "correct"...Air venting is a way to safe hoses and lines, but will show external leaks and deal with potentioal moist/rust problem when storing....
Could be...a piston seal is usually two seals, and each seal from one direction....A "cheap" cylinder might only have one seal on capped side....
Do not be sorry for being organized when asking questions!! I wish ALL questions was this well organized....:D:thumbsup:
   / SA, Single Action and DA, Double Action #9
The correct way is with a DA valve, and one hose to each cylinder. The valve will see the two SA cylinders and one DA cylinder.
Deere 350G LC (A53317)
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
