SAE ports/fittings on a 1980 made in Japan....
   / SAE ports/fittings on a 1980 made in Japan.... #1
montejw
NW WA State
1980 AC 5020
Would there be SAE ports/fittings on a 1980, made in Japan AC 5020? It would seem odd to me if there were, being that the rest of the machine is metric. It has an AC FEL mounted to it with a diverter valve for switching the hydraulic pressure from the FEL to the 3 pt hitch.
If the hoses/fittings are SAE, where would the metric start/stop and the SAE start/stop? Do you think the diverter has both?
Monte
   / SAE ports/fittings on a 1980 made in Japan.... #2
If there is a changeover point from metric to SAE I would think it to be associated with the loader and would probably be from the diverter to the loader spool valves.
Good luck.
Good luck.
Thanks. I guess I get the wrenches out and see if I can tell metric or sae.
Monte
   / SAE ports/fittings on a 1980 made in Japan.... #4
And poossibly calipers and thread gauges. Good luck, mixed Metric/SAE units are always a pain.
Oh joy.
   / SAE ports/fittings on a 1980 made in Japan.... #6
Ya just never know what happens on old tractors. I am working on a 55 ford 850 with a ford 711 1-arm loader. I have a ford 55' 660 just like it with a ford 722 1-arm loader. i never noticed that the 711 loaders bucket cyl wasn't original, like the 660's cyls were. When i was plumbing my hoses, i saw that what i thought was a 1/2 pipe port on the cyl was loose.. turns out it was a #10ORB fittin in the cyl ( more like 5/8 ).. Wow.. a further look and the cyl is komatsu or kobelco.. go figure...Threw me for a loop finding an non sea fitting like that on an old 'merican tractor..
Soundguy
Monte
Soundguy
Hard to say what's going to happen on this. Tractor made in Japan. I'm assuming the loader was made is the US, but don't know for sure. Have to find some specs for hydraulic fittings.
Monte
   / SAE ports/fittings on a 1980 made in Japan.... #8
Monte
Try Discount Hydraulic Hose. They have downloadable catalogs and sell metric, japanese and British Standard fittings and conversion fittings to NPT/JIC.
Thanks, downloaded the catalogs. Now I just need to figure out what the fittings are on the tractor.
Monte
   / SAE ports/fittings on a 1980 made in Japan.... #10
Some of the ports on my Satoh (late 70's) are npt.
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
Harrell 3605 (A50123)
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
Brush Bandit 200UC (A52377)
Brush Bandit 200UC...
