Safely cutting tall grass with Scag Freedom Z - 28 hp
   / Safely cutting tall grass with Scag Freedom Z - 28 hp #1
hylly
Weyers Cave, VA
John Deere
I have a 2 acre field of 12"-16" grass that's gone to seed. Can I safely mow this with a 2011 Scag Freedom Z, 28 hp Briggs, without overworking the engine?
I'm guessing no problem, but wanted to get other opinions.
   / Safely cutting tall grass with Scag Freedom Z - 28 hp #2
Sharp blades and if it's thick raise the deck to 4" or so. If its just a few shoots that tall then regular height should be fine. If it bogs the engine than you 'll need to raise it.
   / Safely cutting tall grass with Scag Freedom Z - 28 hp #3
Just ease into the brush with the deck all the way up.
Then successively lower the deck with each pass afterward.
I'd say a minimum of two passes and possibly a third.
Do I really hafta mention keeping the discharge pointing outward?
   / Safely cutting tall grass with Scag Freedom Z - 28 hp #4
Be careful if the cutter deck is shaft drive, if the tall grass gets tangled around the shaft that enters the gearbox in the front, it could compromise the seal and it will leak
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
