safety chain connetor
   / safety chain connetor #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I have a 2010 F150. The attachment points for the trailer safety chain is flat steel with a slot cut in it. the distance from the edge of the plate to the slot is deeper than most hooks. The slot itself is then not that wide. Can I use a shakle or something in the slot and connect the chain to that? I pull a 7000lb horse trailer and a 5000lb flat bed.
   / safety chain connetor #2
I don't know if it's legal but I use a shackle rather than fight with the hooks.
   / safety chain connetor #3
As long as the shackle is load rated you should be fine. I just use the hook on mine and shortened the chain, however my safety chains have deep hooks that clear the slot edge. They also have that spring flap closure thing.
Hope this helps
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2020 Kinze 3505 High Speed 6/11 Planter (A52748)
2020 Kinze 3505...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
2015 FREIGHTLINER CASCADIA(INOPERABLE) (A52472)
2015 FREIGHTLINER...
