Safety override?
   / Safety override? #11
On my TC33D if I apply the parking brake and place the range selector in one of the neutral positions I can get off the tractor without it shutting off.
I guess I should have specified my tractor has a Hydrostatic transmission. It has a range lever for I, II, III speeds with neutral being between I & II and II & III. Forward and reverse is controlled by a large curved/arched foot pedal and its position doesn't matter since you have to be in neutral to get off the tractor to keep it running or to start it.
   / Safety override? #12
On my tc33d, I have always been able to get on and off with the PTO engaged without doing anything and it stays running. On my MC 35 (front deck commercial mower with HST), I got so sick of it cutting off every time I got off to pick up some trash that I cut the wire to that switch and then tied the two ends of the cut wire together and bypassed that stupid switch. Maybe I am a renegade.....but I sure am glad I did it!! Good luck on whatever route you take.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2019 Chevy Cruze Sedan (A56859)
2019 Chevy Cruze...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
Auger Drill Bit (A56857)
Auger Drill Bit...
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
