Sand as Pre Road Base
   / Sand as Pre Road Base
Definitely won't be "wet" because it will be so well protected from above. The moisture it gets will be from below and sides of the native soils. Dry sand seems to be too loose and sloppy, while damp sand holds and packs better. The right amount of moisture is key for compaction. Remember, I live in VT, not Nevada (it's been raining for two weeks straight) and it would be impossible to keep it dry. On average, I'd expect it to get about as damp as a wrung out spung. I think compacting it before the fabric goes down will help too. I'm going to rent a vibrating compactor to get the firmest surface I can before the crushed stone shows up.
   / Sand as Pre Road Base #12
The bad thing about sand is that it can wash out easy. Larger stone or a graduated mix tends to stay more where you put it, even with some water flowing through. The fines may go, but the larger stone will stay. With sand, once a channel of water starts flowing, the surrounding sand just keeps erroding as well.
Even under my concrete driveway, I was hesitant to use sand and instead used what they call up here in MN a "Class-5" road-base mix of crushed limestone and fines.
- Rick
   / Sand as Pre Road Base #13
Don't do it. Sand displaces easily under uneven loads.
Most people put down 3" rock first, cover with screened 1" gravel, and then you can put a little sand over it for filler if your screened doesn't have enough. Usually, it does and sand is not needed. I put down the geotextile cloth first and have put down a rough mix straight out of the pit. I have some large rock that has kicked off to the side. I now need to buy some more 1" screened gravel to shore up and smooth what I have...Kyle
   / Sand as Pre Road Base #14
Jim,
You don't need to compact sand. It's not compressible. There is no better base for a road that I can think of. It also makes a great road itself! Perhaps you should lay down the sand and use it for a few months before installing the fabric and gravel. You may like it!
I love my sand roads. I can drive on them right after a rain, because they drain instantly. No muddy tracks ever. Another good thing is that sand self levels. A good shower knocks down the ridges and deposits them into the low places and makes the smoothest road you can ever have.
Only downside to sand roads is the sand eventually mixes with the underlying soil. This makes re-sanding necessary every few years. Mine is 3 years old and could use re-sanding. Next application will probably last 5 years. I grow bremudagrass on mine because I like the look of a country lane.
   / Sand as Pre Road Base #15
Sand is great until it turns to sugar. I have several patches of sugar sand on my place and it is almost like quick sand. When it is wet it is great. A sand, clay, and gravel mix seems to work well for a while on the Michigan back roads. Not sure of what the ratios are but if mixed right it is almost as good as black top.
In late Summer I have to carry water with me if I want to dig post holes due to the constant sand slides in the holes.
Farwell
   / Sand as Pre Road Base #16
</font><font color="blue" class="small">( I think you'll be fine though. The woven fabric is incredibly strong. )</font>
Yeah ... was pretty funny looking at some single stones (fist-sized) that were laying on the fabric after the dump truck had run over them .... the fabric was sucked down below grade along with the stone .... some serious pucker. /forums/images/graemlins/grin.gif
   / Sand as Pre Road Base #17
</font><font color="blue" class="small">( Remember, I live in VT, not Nevada (it's been raining for two weeks straight) and it would be impossible to keep it dry. )</font>
I agree, it will be impossible to keep water away from it which is why you'll need to provide a way to drain it if you care about it being dry. Since you seem to be thinking about this material more as a subgrade improvement then as part of the road structure, I guess that's moot though.
Compacting before placing the fabric and using a vibratory compactor are both good ideas.
How important compaction is depends on the gradation of the sand. A poorly graded sand (one size material) won't compact much, and compaction is not very sensitive to moisture content. A well graded sand, with over 10% fines will compact a great deal and compaction is very sensitive to moisture content. I don't know much about VT soils, but glacial tills are more likely to be well-graded, and sediments are more likely to be poorly-graded. This may account for the regional variation in the responses to your question.
Instead of the sand I fell back on the more expensive "dolomite". It's basically crushed limestone....packs extremely well and makes an excellent base. Some people use the 1 1/2 minus material for a finished road, but it's too coarse and it's too light in color (almost white) for me. I'll cap it with some 3/4 minus in a dark grey and that'll look and drive pretty nice.
7' X 8'8" MILITARY STORAGE BOX (A52706)
7' X 8'8" MILITARY...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
Genie Scissor Lift (A54865)
Genie Scissor Lift...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
