Sandblasting?
/ Sandblasting? #1
Casco1
New England
Kubota L series
I have a ton of rusted items I'd like to clean up and was wondering if I can sandblast on a small scale.
What would I need?
Is there affordable equipment?
Who carries this stuff?
/ Sandblasting? #2
Northern Tool, Harbor Freight, NAPA, Sears, Eastwood....... Google search for "sandblasting equipment" got 69K hits. MikeD74t
/ Sandblasting? #3
There are also already 11 threads on TBN on this subject.
Use the search feature.
/ Sandblasting? #4
Even sandblasting small items plan on a LARGE compressor. About 60gal. minimum and about 18-22 cfm. Sandblasters use a lot of air. Also you'll need a good air/water separator. When I priced out the equipment and then the sanding material it wasn't practical for me. I took my stuff to a local and had them blast it for me, cheaper.
Good luck.
/ Sandblasting? #6
I have a gas compressor 5hp 8gal tank with a cheapo sandblaster{15-20 $} that I bought at harbor freight, It worked fine.
/ Sandblasting?
thanks for the replys
/ Sandblasting? #8
I've used almost every size they make. From a hand held unit from JC whitney that looks like a paint gun up to equipment used to strip lead paint off of bridges. If you have enough items to justify the extra cost I like the pressurized units. If the parts are small then I would look into a blast cabinet. Blasting is dusty.
Frontier Forks (A64127)
Frontier Forks...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
AC Unit (A64127)
AC Unit (A64127)
72" Maxilator Grapple MBD (A64127)
72" Maxilator...
2018 John Deere XUV835M (A64127)
2018 John Deere...
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
