Ehanson
OK, These forums are great! I have just learned a few things by scrolling though this thread. First off, my clutch on my Satoh-Mitsibishi S373-D seized "on" after sitting a couple weeks. I tried to break it free by running the tractor around, but to no avail. Tucked it into the shop and started to split it in half. Got it apart and really do not find anything failed. I did find a lot of rust and the bellhousing had moisture droplets in it. The pressure plate and flywheel surface had a hard rusty scale on it. The clutch friction disc has enough wear to have a complete smooth surface, no flutes remaining. So, I find this thread and it talks about frozen clutches! Wow! And while taking the tractor apart, I came across this ell shaped bar, after reading above, I think it is to hold the clutch pedal depressed! I won't know for sure until I get it back together.
I can't believe the friction disc stuck itself to the flywheel or pressure plate.
If I take the Steering column off the tractor, can I see the throw out bearing yoke? Maybe a pair of needle nose pliers can reach the fork and see if is has broken free of the cross shaft.
