Satoh Beaver S-370D not moving
   / Satoh Beaver S-370D not moving
You answerred most of your question. Splined
Thanks, it will probably be a couple months before I get to this as I need to build a shop, (wrenching at -30 sucks), I'll update this then,
thanks
Jim
So I never got my shop built last summer as work was busy. The snow should start thawing soon, and i wouldn't mind having this beaver going again, to help spread gravel etc.
Is it possible to cut into the housing between the clutch and the trans, to make an inspection cover. I though I could then drill some holes around and weld a flange on the piece I cut out, so that it would go back together.
Just thinking it would be easier to fix, not sure how i can fix stripped splines, possibly some sort of clamp (or weld it:laughing:). Not sure how I would get it done with the tractor spit, I guess I should have to split it on both sides?
Anyone have a picture of this splined coupling?
   / Satoh Beaver S-370D not moving #13
Not much point in making an inspection hole. To fix it correctly you'll have to split it. Parts book shows the breakdown.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
