Satoh S630 Rebuild
   / Satoh S630 Rebuild #1
RJB
Gate City, VA.
I finally got around to rebuilding the Satoh after putting it off for over a year. I did the standard rings,rod bearings,main bearings,gaskets and seals, and valves. Cranked the engine and it seems I have a fuel problem. I drained the tank,replaced the filter,cleaned the injectors, and bled the system but nothing seems to help. The runs on one cyl till it warms up and then will only turn about 1900 rpms. When you try to speed it up beyond that it smokes and sputters. I am wandering if the injector pump might have gotten contaminated during the down time with the injection lines removed. I am considering disasembling the pump and cleaning it. I have all the necessary manuals. Any second opinions would be appreciated. /forums/images/graemlins/confused.gif
Thanks Rick
   / Satoh S630 Rebuild #2
I always cover all the fuel lines with aluminum foil when they are disconnected to keep dust out. I would take the pump to an injector shop. They have the proper equipment to fix & calibrate it.
   / Satoh S630 Rebuild #3
Rick,
Where did you get the parts to rebuild you tractor. My engine just went out yesterday. I need either a rebuilt engine or the parts to rebuild it. Please let me know where I can find this.
Thanks,
Tim
timq@nordam.com
timquig@chouteautel.com
Tim,
I sent you an email. I am sure several of the dealers on this forum could supply the parts.
Len.
I appreciate the info. I have just went back into the engine and will let you know the outcome. /forums/images/graemlins/confused.gif
Thanks Rick
2001 GULF STREAM CONQUEST (A51247)
2001 GULF STREAM...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
UNUSED FUTURE FT-HJ6 HD STORAGE SHELVES (A51248)
UNUSED FUTURE...
