uhmgawa
</font><font color="blue" class="small">( I found a rotary timer 0-30mins on Ebay for $2, so it should be here soon. Once I get it, I'll see what circuit and components will work best.)</font>
Verify the contact rating on the timer switch is sufficient for the
amperage draw of the pump motor.
</font><font color="blue" class="small">( Dumb question, though. If the trickle charger is left attached to the battery, as is the line to the rotary switch, then to the motor, will the high current draw harm the trickle charger? Is there some component I have to add to protect the trickle charger during the usage of the pump?)</font>
Most likely not an issue for a mass-market trickle charger which
is designed to be placed across a battery of arbitrary charge state.
The trickle charger will be internally current limited. Then again
you won't be placing as large a load on the battery compared to
cranking an engine starter.
