scored piston on backhoe ---
   / scored piston on backhoe --- #11
Try filling the scratch with JB weld and then sanding smooth.
It may work, what have you got to lose? All you're trying to do is to fill the scratch so that it will engage the entire surface of the seal.
Bill
   / scored piston on backhoe --- #12
Bill
My fear of JB is that it may not adhere well and come off inside the cylinder.
   / scored piston on backhoe --- #13
Get yourself some Corcus cloth. You can try to clean it up a bit. It will likely still leak, but might be a little less. Alot depends on just how deep the scratches are.
You can try to fill and file the scratches use SS or braze. That can work. Wouldnt hurt to try as the rod is already damaged. Honestly though, if your wanting it leak free, your likely looking at a new rod or rechrome and seals/.
   / scored piston on backhoe --- #14
I've seen it done with silver solder (same as braze, but a little more heat). Silver solder holds up better then brazing rod.
Kind of chancy though. Might end up rebuilding anyway.
Can't help to try though...
HHMMM...
I though SS was softer and melted at lower temps than braze:confused::confused2:
   / scored piston on backhoe --- #15
How did an outrigger cylinder get scored? Actually how does any cylinder get scored? It would seem that an outrigger is one of the least used cylinders on a backhoe.
MarkV
   / scored piston on backhoe --- #16
MarkV
Hit by falling rocks, or scraped by the bucket. Some machines can get the bucket close enough to the outriggers for this to happen. At least this has been my experience. Not sure about the OP
   / scored piston on backhoe --- #17
Falling rocks/debris is by far the most common way...especially on an outrigger.
   / scored piston on backhoe --- #18
Yep...not going to be much surface area to work with...
JB Weld is great stuff in the proper applications....don't think this will be a good application.
bingo -- they're way too exposed to dirt and rocks -- :(
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
1262 (A50490)
1262 (A50490)
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
