Sediment bowel necessity
   / Sediment bowel necessity #11
Sediment bowls are very efficient at separating water and other heavier-than-fuel contaminants. Difficulty with o ring and or seal failure is all but certain to be directly related to poor choice of materials or poor installation. Buy the correct seal and install it with care.
:thumbsup:
There are there for a reason, I would never bypass it and wouldn't have a tractor without one in the fuel system.
   / Sediment bowel necessity #12
My two cents; the quality see through in line filtes, such as WIX, are every bit as good as the filter/sediment bowls. Plus, the in line type is less mess and trouble. On my JD farm tractor I only had 34 years of use on it and the top that holds that sediment bowl started seeping around the inlet. Had to epoxy the inlet nipple back in. What poor service! ;-)
prs
There are many instances where an inline filter with a paper or similar element causes a troublesome restriction when installed in a gravity feed system.
   / Sediment bowel necessity #13
Re: Sediment bowl necessity
Ditch it- the weight on the bottom of the tank coupled with the vibration of the engine can eventually cause the tank to leak. $6 inline filter - priceless ( like the fuel tank if you don't have a nice used one)
   / Sediment bowel necessity #14
And the basis for this nugget comes from where?
   / Sediment bowel necessity #15
41 years as a gravely dealer
   / Sediment bowel necessity #16
Filter connected directly to the tank with the filter weight supported by the tank?
I agree, that's a poor design. I'd ditch it, too, and mount the filter correctly so that its weight is supported properly instead of being supported by the tank. Ideally, there should be something flexible between the filter and the tank.
   / Sediment bowel necessity #17
Sounds more like poorly designed fuel tanks. How many million farm tractors and compact utility tractors have sediment bowls screwed into the bottom of their tanks?
Several. In 60 years on the planet and 22 at dealerships I can't recall seeing a tank fail at the outlet fitting.
I've seen more problems from add on in line fuel filters installed on gravity systems.
But then, I've never owned a Gravely. Maybe just as well.
   / Sediment bowel necessity #18
Farm tractors are normally multi cylinder and low vibration. Gravely designed a fan cooled single cylinder in the early 30's without a college education. It was built until
1976. Approx 30ci and offered in 5.5-7.6 hp. Made a lot of gardens, mowed a lot of grass, and moved a lot of snow for tens of thousands. So yes the farm tractors didn't suffer many broken tanks.....
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A53843)
HYDRAULIC THUMB...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
HYDRAULIC FLOOR JACK (A53843)
HYDRAULIC FLOOR...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
