Seldom do I plug a product.
   / Seldom do I plug a product. #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
If you are in a bind having to remove a pressed in bearing or bushing by pulling from the I.D. Sizes 11/16 ro 1-5/8, then this little tool is well worth it. I looked all over and what I found either looked like junk mush metal, or was SNAP-ON tool like expensive.
I was impressed with the quality. It removed the bearing at the bottom of a manual steering box and the top bearing from the shaft column.
Amazon.com: OTC 4421 Pilot Bearing Pulling Attachment: Automotive
   / Seldom do I plug a product. #2
Looks like a useful tool to have around.
   / Seldom do I plug a product. #3
I you run a bead of weld around the inside of a bearing they will fall out.
   / Seldom do I plug a product. #4
Sometimes one must work harder because the tools to work smarter aren't within reach. Brains vs. Brawn but either will pull a bearing.
   / Seldom do I plug a product. #5
They are a handy tool. Another way if you can find a piece of bar the same diameter as the shaft is to fill the bore with grease, put the piece of shaft up to the hole and give it a smack with a BFH.....Mike
   / Seldom do I plug a product. #6
Nice tool:thumbsup:
If the bearings should be replaced it has happened that I've taken a bit of threaded rod and welded to the inner ring and used a slide hammer
Club Car Gas Golf Cart (A44502)
Club Car Gas Golf...
2021 Dodge Ram 1500 Classic Crew Cab Pickup Truck (A44572)
2021 Dodge Ram...
2013 Kenworth T400 Palfinger 20M Forestry Grapple Truck (A44571)
2013 Kenworth T400...
2012 WESTERN STAR 4900 (A45046)
2012 WESTERN STAR...
40' 6 Door Container (A45336)
40' 6 Door...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A43003)
2015 INTERNATIONAL...
