These valves are on a Toro Reel Mower. The (I think it is called a Subplate) has one high pressure line in. On the output side - lines run to 3 in-series hydrualic motors (Which have a proportional dial switch for speed control) the other line out goes to a set of 3 hydraulic cylinders that lift the cutters - Operated by a two way joystick.
I am just in the planning stages for this machine. I want to eventually add a rotary cutter to the front and I only have limited funds so I am trying to be creative on using the things that are already there. However, The wiring for the selenoid valves go back to a central controller box. I am just trying to decide if there is any way I can use these valves or if it might be better to take them out and use manual valves. Thanks for all of the information on selenoid valves. It helped.
