Septic Help!!!
   / Septic Help!!! #21
Let me be clear and say, nothing is overflowing, well...... I have had to loosen/remove the cap on the cleanout enough to let the fluid drain out into the flower bed. Otherwise, showers would be backed up and so on. We only flush the toilets if need be, #2. We have been following the mantra "if its yellow, let it mellow. if its brown, it goes down" for quite awhile now since the first incident roughly a year ago. I can open both clean out caps and both are filled with "water". One cap goes to the house while the other goes to the septic.
You say not "over-flowing"...you should add "yet". Your house is not that old. How many lids do you have on your tank? Modern systems will have 3..."stuff" goes into the first chamber from your house. That has a baffle on it...I learned the hard way that "extra strength" toilet paper used to excess by kids that don't understand plumbing will clog that baffle quickly. To test open that lid and check that baffle. You might find a big wad. Now not so sure about Texas but around here I wouldn't call a plumber...I call the septic pumper...a good one will know your system just based on the pumping.
   / Septic Help!!! #22
Grey Water systems are not forbidden everywhere...
   / Septic Help!!! #23
I'd call a plumber first to throw a hail Mary that you have a clog in the line. Drainfields should last MUCH longer than this.
Don't know where you are, but just plumbers aren't septic tank people.. I'm a master plumber, but I don't do septic..
Just call around and get prices on replacing the drain field lines)... Here, they have to be inspected ,and approved by the health dept after they are installed , or replaced
   / Septic Help!!! #24
I'd say almost all plumbers here stay away from them... even the roto-rooter types for cleaning.
I't's become specialized.
   / Septic Help!!! #25
I have a DIY system that conforms to code and it was pumped for the first time after 22 years. Was perfect.
(Pumper said it was like about equal to a 3-4 year old system.)
We all are on septic here and I was a local 'go to guy'.
A lot of things affect a septic field, some of which are:
Bleaches, (Javex etc) as well as those toilet tank capsules that the ladies like to use.
All great all that stuff kills bacteria, but bacteria is what makes a septic system work.
Even some dish washer detergents should never be used.
Food hashers (garborators) should not be used.
We learned that one should not induce more water than necessary hence showers vs baths, low flush vs old traditional toilets. (most of us installed trailer toilets).
Let me guess, the wife and three teens take 20 min showers twice a day?
Snake cameras that connect to your laptop can be had on EBay for as low as $30.00 or so, and that up to 30 meter range. Might be an option to locate any plugs or defects. Might be an option.
Tree roots are a frequent problem as are errant toys, diapers and J cloths.
House guests often unwittingly dispose of items that are a big NO-NO in septic systems.
We learned that 'designer TP' is a no no as the inked part will not dissolve easily. Single ply is what the experts suggest for septic systems.
If you can DIY a cure you'd be many $$ ahead as once a contractor enters the picture permits and inspections could get costly.
My 2 cents!
   / Septic Help!!! #26
When I retired a couple of years ago I was a licenced septic installer and designer in Washington state. The first thing I looked for when checking out a failure was for running toilets and dripping faucets. A small drip in the shower or sink can add up to a lot of water, a running toilet can be up to several hundred gal/day which will flood any system.[ check by putting food coloring in tank than tape the bathroom door closed for about 4 hrs than ck for color in bowl fix flush valve than ck the rest of the toilets the same way CHECK THEM CAREFULLY] if good than check for downspout water getting to septic tank area where it can sink in[run hose down downspout really flood area so you can see where the water really goes.
PM and I can lead you through a complete diagnoisis
Greg
   / Septic Help!!! #27
I'm constantly battling things that have no business going down the drain... number one offender at rentals is baby wipes and "Flushable" cleaning pads...
Incredible that stuff that folks put down the toilet.
One of my friends retired to a place where the soil doesn't perk well... they were told the previous owners had lots of trouble... my friends lived there 22 years and zero trouble... they were extreme as in only biodegradable soaps... no germ killing chemicals, took out the garbage disposal and zero toilet paper... next to the toilet was a little paper bag for toilet paper and each night it went into the wood stove...
The septic guy for the county was amazed and every 5 years they got a pass grade... all their neighbors were going to mound systems with pumps.
   / Septic Help!!! #28
Our place was built in 2001. I bought it in 2008 and promptly started building the front yard up level from the steep slope it was originally where the septic was one wheelbarrow at a time. (This was pre tractor days!)
My wife chewed me out one night for throwing a frog in the toilet which she found one late night unexpected during a late night bathroom run.
Then the drains started backing up and running real slow.
I thought the septic was full. So I unburied where the tank was by shovel and metal detector looking for the pump out lid/hatch.
Of course it took a big **** hole to find it and I unearthed the drain line from the house where it went into the tank. There the line was bent down at an unnatural angle and there was an opening on the top of the joint. Roots had got in and nearly clogged it up there. I also pointed it out to dear wife who finally believed me that I had NOT put a cold frog on her hiney that one cold night long ago.
You oughta been there for that first reach in there to start pulling those roots out though. It took a minute to make that first grab I gotta say. Tryed to get dear wife to do it since she had falsely accused me of something but she only said that was for all the times she hadn't caught me out and told me get busy. And strip out in the yard and hose off before I was allowed back in the house!
   / Septic Help!!! #29
I work around a lot of septic people.. Most systems here that give problems ,are the systems that were installed yrs ago , when they used clay pipe sections , and concrete pipe sections for the field lines..
Over the yrs, this clay, and cement will deteriorate ,and collapse.. When the tank fills,, there is no place for the water to go.. Time for new lines ...... This https://www.plumbersstock.com/adsar...chamber.html?gclid=COitgeGDusoCFc0lgQodvfgPjw is the type material they are using for field lines here now
   / Septic Help!!! #30
Our ground started to stink a couple of years ago and I had a thought. We had a brand new unused chemical toilet in the shed with a bottle of chemical supplied with it.
I poured a dose down the loo and within a couple of days it had all cleared up. The ground stays dry now even after good rain. Might be worth a go...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
30ft Highway Trailer Co. Lowboy (A53473)
30ft Highway...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
