Serbian made FPM Agromehanika 2 wheel tractor
   / Serbian made FPM Agromehanika 2 wheel tractor #11
I noticed in the description on the English page of the FPM that the 410/414 have proven german technology. But only in the Serbian version of the site under "history" is that explained:
"Saradnja sa IMT FMM – Knjaževac u proizvodnji priključaka za motokultivatore po licenci AGRIA WERKE – SR Nemačka zaključena je 1974.godine"
"Promena privrednog ambijenta od 2000-te godine, dovela je do proširenja tržišta i kontinuiranog povećavanja učešća izvoza u ukupnoj prodaji. Kako bi što bolje odgovorili zahtevima tržišta uveden je sistem kvaliteta ISO 9001/2001. i uspostavljena je kooperacija sa firmama KUHN – Francuska, Breviglieri-Italija i AGRIA-Nemačka."
So almost certainly these machines will be copies made under license from the German Agria company. Which suggests at least that the design is good.
The mass of those FPM machines is almost what the Goldoni Special series has (and they are still available from Goldoni as "My Special" or from Labinprogres Special).
My personal bias is that the heavier machines are better.
How much of a price difference are the Lombardini motors vs the Kama motors? What warranty do the sellers offer you?
Than you very much!
I will look into your solution :)
A blessed day!
Why are heavier machines better?
Thanks,
A.
   / Serbian made FPM Agromehanika 2 wheel tractor #14
Weight generally equals traction, with everything else the same.
   / Serbian made FPM Agromehanika 2 wheel tractor #15
It is said for the rotary plow that weight is helpful. Not just for traction, but also to give it more inertia.
It is always possible though to have a lighter machine with detachable wheel weights, which I what I think is done with the mostly lighter BCS machines.
I can't say very well from personal experience, as I don't have a a rotovator for the light weight Goldoni Eco that I use for mowing.
Hristos Anesti!
Thank you! I will consider to buy also weights!
   / Serbian made FPM Agromehanika 2 wheel tractor #17
Alithos Anesti!
Wheel weights for the lighter machines should be considered.
For that large size FPM, I think it is heavy enough on its own. The Goldoni I use is about the same weight, and I have not felt like I would need wheel weights.
I suppose by now it is nice warm weather where you are. The past week finally started being warm here.
   / Serbian made FPM Agromehanika 2 wheel tractor #18
   / Serbian made FPM Agromehanika 2 wheel tractor #19
Odd music, but they sure look to get the job done!
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
6ft LandPride Box Blade (A51573)
6ft LandPride Box...
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
