Series 1910 Ford Tractor
   / Series 1910 Ford Tractor #1
GilbertKnight1952
Hello I'm new to this site. I was wondering if anyone could help me with some problems I'm having with my series 1910 Ford Tractor. I need to know how to adjust the lifting pressure?? Any takers on that?? Just let me know something if you know something, lol. Thanks alot I appreciate it very much.
   / Series 1910 Ford Tractor #2
You need to know what the pump specs are, and then install a hyd gage in the input to the FEL, and test the pressure. DO not exceed the pump pressure or the valve rating. If the pressure is low, then you can increase the pressure and therefore increase the lift power.
You change or adjust the pressure by increasing the force on the relief valve, Some PRV's have shims that you can add to increase the pressure. Other PRV's are adjusted by screwing down a screw/bolt which puts more pressure on the relief spring, and therefore increasing the system pressure.
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
Club Car Utility Cart (A55851)
Club Car Utility...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
48x4 Mini Skid Trencher (A56436)
48x4 Mini Skid...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
Motorcycle (A59231)
Motorcycle (A59231)
