Freds
Veteran Member
The dealer picked up my bota for its 50 hour yesterday. There were some other problems I wanted him to look at, too. A couple weeks ago I couldn't get the bucket into the downward float position. They came out, sprayed a little PB Blaster up into the joystick linkage and that lasted about a week. Then, two days ago I couldn't get the bucket to tilt down. Again, there is a float position for this so you can drop a load faster. I had never used it so maybe that contributed to the joystick freezing up again, but in this case I couldn't even tilt the bucket.
They are going to check into that loss of power thing too. The one where the engine bogs down from a high rpm when travelling in high range with no apparent load change, such as starting up a hill. It's almost like a fuel filter is clogged and backing off on the HST pedal picks the rpms back up again.
It also would not move forward the other day after warming up. I could get it to move slightly (not much room) in reverse, but forward was almost like it was frozen to the ground. I even looked at the tires to see if there was a flat spot /forums/images/graemlins/tongue.gif
Anyway, I hope they find something wrong with the power losses because I don't want them to be a reoccurring, nagging problem and wouldn't you know... there's a little snow that could used plowed this morning /forums/images/graemlins/frown.gif
