Setting Rear Height on Brush Hog
   / Setting Rear Height on Brush Hog #31
</font><font color="blue" class="small">( Well,I'm one of those who say it is unnessacary,,,,,your lift arms hold the front up,,if using lift arms only,,lift arms don't lower,,they just go up when 3 point is set,they don't go down unless you make them or they leak down,,,,so you got them holding the front up and then you got those check chains holding front up,,both doing the exact same thing,,,,nither one will let front of mower lower,both will let mower front raise,,can not for the life of me figure out what good those check chains are doing )</font>
Thingy.. you are only thinking baout tractors with good- non leaky lifts, and position control on their 3pt lift. You are not giving any thought to the hundreds of thousands of tractors made with draft hyds only.. no position control. Ford 9n, and 2N come to mind, as well as fergy TX-20, 30 .. etc..
Soundguy
   / Setting Rear Height on Brush Hog #32
Why not just keep the pressure+++++wear and tear+++++etc. off the hydraulics and use check chains?++++++Makes sense to me. ++++++What do you think of my hesitation speech?++++++I kind of like it++++++personally,++++++don't you?
   / Setting Rear Height on Brush Hog #33
Love it,,,and understood it,,,more people should write that way,,,,,,,,,,,,,airbourne!!!!!!!! no,,sound man,,,,not forgetting that at all,,said if you needed it,,,well,,,,you needed it,,,and its a good thing,if you needed it,,,,its just the guy who posted this thing about these chains,,,showed a picture of a 18,000 dollar new tractor,,,,surely,,,it don't need it,,,,,???????,,,,,,,thingy
   / Setting Rear Height on Brush Hog #34
</font><font color="blue" class="small">( Love it,,,and understood it,,,more people should write that way,,,,,,,,,,,,,airbourne!!!!!!!! no,,sound man,,,,not forgetting that at all,,said if you needed it,,,well,,,,you needed it,,,and its a good thing,if you needed it,,,,its just the guy who posted this thing about these chains,,,showed a picture of a 18,000 dollar new tractor,,,,surely,,,it don't need it,,,,,???????,,,,,,,thingy )</font>
Well, no matter the cost or sopistication of a tractor, there should be plenty of nice chains hanging off of them. It dresses them up and makes cool jingling sounds like heavy-duty jewlry. /forums/images/graemlins/cool.gif
   / Setting Rear Height on Brush Hog #35
Well,,that makes sense to me,,,,,love that sort of thing,,,yeah baby,,,,,,,no arguments there,,,,,bang and rattle,,,good stuff,,,10-4,,,over and out,,,roger roger,,,thingy
   / Setting Rear Height on Brush Hog #36
</font><font color="blue" class="small">( it,,,,its just the guy who posted this thing about these chains,,,showed a picture of a 18,000 dollar new tractor,,,,surely,,,it don't need it,,,,,???????,,,,,,,thingy )</font>
Well, "the guy" wouldn't do without the chains. For those who choose not to believe, I have no answer, but for anyone else, here's the reasons.
- Yes, if you have old or leaking hydraulics, the setup would be nice to keep the position constant.
- However, it keeps the position, on a new tractor or one with good hydraulics, at the same point every time you lower the 3pt arms. No looking back, no wondering if you've set it exactly the same as the last time.
- Even if your tractor has a little set-screw stop or some other means to make a set 3 pt stop point, this is still easier and eliminates removing the stop point for the lever every time you switch implements.
- The chains allow for precise side to side level setting. This is very handy when you have a 6 foot or larger deck.
- The setup does provide superior "float" function than can be maintained with just the lower arms and a toggle or flexible top link or top link connection. (I recently created a small model of this and found that the connection of the lower chain to the deck front, at a point several inches lower than than the pins, is key to the scissors action.)
I'm not selling this setup. I don't get any benefit, whether you use it or not. When I bought my Woods mower, it was already there and briefly described in the manual. As I said, I wouldn't do without it, but no longer wish to debate it. I posted originally for the benefit of others only.
   / Setting Rear Height on Brush Hog #37
OK guys, lets get past the fact that the check chains only hold up the front of the mower. The chains that Woods sent with the mower and the bridle that Sidewinder has pictured (although I haven't figured this one out) are designed to hold the mower more level on uneven ground. The rear axle is the pivot point of the hitch as the tractor front wheels follow uneven ground. The lift end of the lift arms are about 2 feet beyond the rear axle. If the front end lowers a few inches, the arms raise the front of the mower, leaving longer grass in that area. If the front of the tractor raises, then the mower drops and either scalps or slides on the runners. If the front of the mower is supported on the check chains that are hooked much closer to the pivot point, the up-and-down pitching of the front of the mower is much less. Thingy touched on this briefly. I found a picture of a setup (Ford or Dearborn if I remember right) that uses a chain over a rigid top link to support the front of the mower. I'll try to find the picture and post the link, or maybe some will recognize and repost the picture. I think this would be better in that it would counteract the up and down pitching. I'd try to experiment with the triangular suspension, but would much prefer to buy one that is already thought out. Has anyone seen such an arrangement for sale?
   / Setting Rear Height on Brush Hog #38
I've never had a problem with a set of check chains from the toplink connection point to the lift pins, a rigid toplink and a couple from the toplink to the mower that allowed a few inches of play.. Most manufacturers either have a slotted attachement point for this.. or a "U" shaped couple piece that allows for a few inches ov movement.
I set my mower height this way. Decide on mowed height.. st the front at desired height using lift arms and no toplink. then adjust tail wheel to get the rear of the mower 1-2" higher than the front.. .. then install and adjust toplink to be in the middle of the 'play' at the desired cut height... adjust check chains if using them. Out of 5 different style/brand and configuration of mowers.. after a a bit of practice.. the all mow nicely... Only rare odd teraine features will cause deck to ground contact.. like wheels falling into large depressions.. or high areas like ant mounds.. etc.
Soundguy
   / Setting Rear Height on Brush Hog #39
Gene, please make sure you adjust it so the rear is not too much higher than the front. As Soundguy wrote, 1" to 2". But bear in mind that 2" on a 4' cutter is a lot steeper angle than 2" on a 6' or 7' cutter because the rise to run angle is 50% to 75% lower (as a %) on the 6' and 7' cutters than it is on a 4' cutter.
Rotary cutters are great at launching debris long distances. Using a 5' Howse, I once launched a partial piece of plywood and it flew 30 yards like a high velocity frizzbee.
Here is a link to a discussion that got hung up a bit, but makes a point. Rear of Rotary cutter "NOTICABLY" higher than Front
   / Setting Rear Height on Brush Hog #40
Gene, I think Jinman posted such a picture, with a hog out behind his old Jubilee, if I understand your post correctly. This works quite well, but results in a VERY flexible top link connection, more than what some folks are comfortable with. I've even seen some variations were the top link was a combination of a solid piece and chain. Both my Woods mower and brush hog, have flexible top link connections however, so such a chain-type top link really isn't needed. My brush hog connection can move about a foot, while my mower can only move a several inches, so I guess it might benefit from such a connection. Bottom line however, if you already have a flexible top link on your hog, you probably won't see a whole lot of improvement.
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
205196 (A52706)
205196 (A52706)
5th Wheel Hitch (A59230)
5th Wheel Hitch...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
