Setting up a moldboard plow
   / Setting up a moldboard plow #11
One other thing... once you have it working well, take measurements of all the adjustments and record them for next season. It'll be nice to just mount the plow and go next year.
I used a blank page in the manual to record my settings, like distance from ground to center of each ball end, (mine was exactly three inches different, right side being lower), distance from lift arm to right side tire with sway chains tight, draft depth settings, etc.
Sean
   / Setting up a moldboard plow #12
I use a 101 plow too, also on a tractor with wheels a bit too wide. It will run to the right of center just fine. Run it up on 6" blocks and adjust the plow so both of the shares are running on the ground, leveled both ways. Sounds like you might have done that already. Let it float (left and right) and it will find it's spot to trail the tractor which will be right of center in our cases. The number of bottoms doesn't change a thing since the first bottom is always in the same place, and has the 3ph adjusted to it not the other bottoms.
   / Setting up a moldboard plow #13
Exactly the same thing I was thinking. 95% of your setup is on the first bottom, the others are just along for the ride. Doubles and triples (or more) are easier to set up than singles when trying to judge whether you're level from side to side. A small error is more visible over the wider span. More than a double is probably harder to be consistent with over rough ground though, at least I would think so.
Sean
   / Setting up a moldboard plow #14
I have a MX4700 and to get the plow to run center the tires would have to move in. They are already in as far as they will go.
Answered your own question. Your description above is why your top link runs at an angle. Nothing you can do about that. It's not a perfect situation but it'll work.
The reason I say it's not perfect is because the "drag" or "pull" of the plow is going to be slightly greater on the side the top link is leaning toward. Won't be noticeable on your setup because your tractor easily pulls your plow. If you were plowing to the maximum capability of the tractor you would notice tire slippeage on that side or a difficulty in keeping the tractor straight in the furrow. Properly set up, little steering wheel effort is required. Back when I was a smoker I've let go of the steering wheel and got out my cigarettes, lit one and then put my hand back on the wheel while going thru the field with no issues.
   / Setting up a moldboard plow #15
With the tractor in plowing position, the right wheels are in the furrow. If you have a level concrete floor, drive the left wheels of the tractor up onto blocks of height equal to the desired plowing depth. Now, the floor represents the bottom of the furrow. In this position, the plow should be level to the floor. Most mounted plows have an offset in the beam across the front to which the 3 pt lower arms mount, so that the plow frame is approximately level with the right wheels down in the furrow. With the tractor tilted up on blocks, adjust the drop links to make the plow level in this position. Now, look at the top link....is it still not centered?
If you have adjusted the drop links to make the plow level with the tractor level (left side not up on blocks) then the top link will be thrown to the right of the tractor center, because a line passing through the lower link pin centers is tilted down to the right.
Make sense? Take a look.
I'm about to set up a plow tomorrow, so I'll be going through this excercise. However, before I do, I'll start by making sure the 3 pt drop links are set at equal lengths.
   / Setting up a moldboard plow #16
With a mounted plow, the 3-point top link SHOULD be straight in line (front to rear) with the centerline of the tractor. There is SOME leeway with that, but "in a perfect world", it should be straight.
In that same "perfect world", you set the tractor to match the plow, and NOT the other way around. Any plow has what is called the "line of draft". That is essentially the center of the work load.... That lime of draft should be centered behind the tractor, THEN, the furrow side rear wheel of the tractor should be set just to the outside of the front bottom. On a typical 2-bottom plow, that is 22" to 24" from center line to inside of rear tire sidewall.
That width changes (increases) with a 3-bottom plow (or larger)
With the majority of newer tractors having all sorts of different tire combinations, (ie R4,s turfs, ect) and the lack of adjustability of track width, SOME deviation from "the rules" may be needed to get a plow to track behind any given tractor.
As far as the offset drawbar..... The offset is there to level the plow when furrow side wheels are in the furrow. Rotating that drawbar is NOT to be used to level the plow from side to side..... That's a job for the leveling cranks on the 3-point hitch. Rotating the offset drawbar will skew the rear of the plow left or right depending on which direction the drawbar is rotated. That will put more (or less) pressure against the landslides, which will in turn make the plow want to follow left of center or right of center. (and you DO NOT use stabilizer bars/links on the 3-point hitch to hold the plow where you want it.) Skew the rear towards the furrow and the plowtends to track to the LAND side, as pressure against the landslides decreased.. Skew the rear of the plow towards the land side, and the plow will track towards the furrow side, as pressure against the landslides is increased.
If you have more than enough tractor (weight and hp) for the particular plow you're using, it's possible for a tractor to "manhandle" the plow when it isn't in proper adjustment. If you're operating anywhere near peak draft load, a plow would need to be "by the book" or else it would pull like the proverbial boat anchor.
With a well designed plow, attached to the tractor correctly, and everything in proper adjustment, and the plow glides through the ground ALMOST effortlessly. Deviate from "perfect" very far and you suddenly have a fight on your hands.
Think of a plow in the ground much the same as a rudder on a ship. If it is locked into position, the ship won't turn. A plow needs to be able to move side to side in order to allow some degree of control with the tractors steering. With a plow setting dead level when in the ground, you minimize the plows tendency to raise up out of the ground. Minimal wear on the shares is the key to "suck". (The plows natural tendency to pull itself in the ground) Too much nose down attitude, and the plow wants to keep pulling down, creating excess load on the tractor. Too short on the top link and the plow dives into the ground. Too long, and it tends to want to raise up. (or never go in the ground to adaquate depth) "Just right" with the top link and the plow pulls easily and has but a little compression on the top link, nor will it have excessive tension on the top link. And as mentioned, side to side directional control is acheived with rotation of the offset drawbar. It's just like sticking your hand out the window of a fast moving car....hold the hand flat and everything is effortless, but curve the hand and it wants to go up or down....You want the plow to pull as lightly and effortlessly as possible.
But...Since we aren't in a "perfect world", and tractors today are NOT designed with moldboard plows in mind as a primary duty, you have to make compromises with any adjustments.
   / Setting up a moldboard plow #17
I love reading these threads. learn something new from every one of them.
The most important thing I've learned lately from this forum and from pulling my plow is that if everything is adjusted correctly, the plow will, as FWJ says, just glide through the ground.
The latest lesson I've learned is to let the plow follow the tractor and not force the plow to a spot behind the tractor. I disconnected my sway links from my lower lift arms and the change was noticeable. The plow finds it's own (correct) place behind the tractor. I had to make a minor adjustment of the the right bottoms landslide but other than that, it's much nicer to pull than when I had it locked down.
Now, I need to figure a way to keep the plow from flopping from side to side when I lift it. Some tractors have sway blocks that only engage the lift arms when they are up. Others, like mine, don't have that. I'm working on a solution.
To the OP welcome to the dark world of those of us who like to pull a moldboard plow and good luck.
   / Setting up a moldboard plow #18
Nice thread and lots of good info. I just picked up a 2B-14" dearborn. I am now trying to learn how to plow the field, before I make the attempt with the 8N. All I did was 5-6 100yrd passes in the field with standing water and I can see its not at all as easy as it looks. Now to find a pattern, Zanboni style, inside out.....:confused: Thanks for the set up info....
   / Setting up a moldboard plow #19
what is the inside measurement of the rear tyres, is it the same at the front wheels, size of rear wheels, also furrow width if 2 bottom plow. is the draft bar wide or narrow,if cranked draft bar viewed from behind should be down on the right up on the left. if single furrow measure across the share at rt angle to the wing it should aproximatley 2/3 to 3/4 the width u want to plow for grassland .some plows have full width shares depending on moldboard shape .a little info or some photos would help. cammax
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
Swamp Buggy (A48082)
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2012 Chevrolet Impala Sedan (A48082)
2012 Chevrolet...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
