Grading Setting Up a Rear Blade on 3pt *DELETED*
   / Setting Up a Rear Blade on 3pt *DELETED* #2
Re: Setting Up a Rear Blade on 3pt
If you stand behind your tractor, you should have an adjustable link for the right side lower link (hitch point for the implement). The adjustable link will be like a large turnbuckle.
That levels the implement (rear blade) side to side. You can use a level if you like, but I just use a calibrated eyeball.
You mentioned the threads on the adjustable link don't lock in....isn't there a jam nut on that link? There should be...
As far as side to side sway, lower the blade and tighten up your anti-sway links. You'll still get some side to side movement (say...½" or so), but that's about it.
Sorry, should have read the manual first prior to asking stupid question. So, in another brilliant moment, I figured I'd delete the post so as not to waste more reader's time. /forums/images/graemlins/crazy.gif Well, this whole thread could have gone better. /forums/images/graemlins/tongue.gif
Roy - thanks for the input. I've pulled out the manual and dialed in the linkages.
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2015 KENWORTH T300 SERVICE TRUCK (A51243)
2015 KENWORTH T300...
