Shake Rattle And Roll
   / Shake Rattle And Roll #11
Mike,
My tractor's diesel clatter and rear end noise are so loud I would be lucky to hear any other noise over it.
I have nightmares of the FEL kit loosening and ruining some of the threads in the main housing. This is because I have had several 5/8 bolts loosen on my FEL kit, and even lost one. I replaced it with a grade 8, and tried to find some Belville springs to replace all the split lockwashers. The guy at the hardware store never heard of Belvilles. 200 Lbs-Ft of torque on the split washers made them gape open, but they are holding so far. I learned my lesson! Every time I grease, I do a slow, methodical check on all bolts with impact wrench in hand. I think that impact wrench is like an innoculation against bolts loosening! /forums/images/graemlins/smile.gif
   / Shake Rattle And Roll #13
Great just what I wanted to here a "Normal" sound. /forums/images/graemlins/grin.gif Thanks for the help everyone.
Tell me something, when I do get older and start loosing my hearing does it help block out the wife's nagging? /forums/images/graemlins/grin.gif That would truly be a benefit to getting older. /forums/images/graemlins/smile.gif
<font color="blue"> I have nightmares of the FEL kit loosening and ruining some of the threads in the main housing. This is because I have had several 5/8 bolts loosen on my FEL kit, and even lost one. I replaced it with a grade 8, and tried to find some Belville springs to replace all the split lock washers. The guy at the hardware store never heard of Belleville's. 200 Lbs-Ft of torque on the split washers made them gape open, but they are holding so far. I learned my lesson! Every time I grease, I do a slow, methodical check on all bolts with impact wrench in hand. I think that impact wrench is like an inoculation against bolts loosening! </font>
Have_blue you can bet that I'll be checking mine at every 50 hour interval from this point forward. I never would have imagined that they would/could work loose so quickly. It made a believer out of me also.
Time to make the impact wrench earn its keep. /forums/images/graemlins/laugh.gif
   / Shake Rattle And Roll #15
Thanks for this heads up. I went out and checked my nuts and found that 3 out of the 8 were not tight. This is a great example of the value of this board. If we all share our problems, others of us learn. Thanxs,
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
LOT: (2) Cargo Van Shelving Units, (2) Steel Shelves (A59076)
LOT: (2) Cargo Van...
NEW 5/16x7ft G80 Chain Sling Double (A59000)
NEW 5/16x7ft G80...
1293 (A58374)
1293 (A58374)
LOT OF CHICKEN EQ. NEST, BROADER & FEEDER (A58374)
LOT OF CHICKEN EQ...
PALLET OF MOTOR PARTS (A58374)
PALLET OF MOTOR...
