Shallow Gas Well Drilling & Water Wells....
   / Shallow Gas Well Drilling & Water Wells.... #11
craig, From my experience, They drilled 14 gas wells on my land in the last 10 years and as long as the wells are done by the standards set by our Ky Oil and Gas people, the wells will not contaminate the fresh water supply. I think they Fracked 5 of mine and the wells were only 600-700 ft in the shale. No problem with the Fracking. Ken Sweet
Craig if they are fracking it I think it will be a horizontal its not a cheep process and usually they drill multiple wells on one pad site to minimize surface disturbance (actually cheaper for them too)
here is a good link on how its suppose to be done.
YouTube - Chesapeake Energy horizontal drilling method
tom
Tom,
According to what the company is telling me they only do shallow wells and that doesn't include horizontal drilling. The do frack the wells, it all depends on the flow rate once drilled from what I am being told, but most of them are fracked.
Ken, thanks for the advice. I have heard if its done right there are no problems, but I'm always skeptical until its done and over with and I can see for myself. The driller has told me that they drill up to 100 wells a year, and there are on average 30 households listed a water purveyors and they might have one household a year that has an issue and it's usually muddy water. After some flow and flushing it usually goes back to normal with no problems.
Time will tell, and we'll see if it's done right.
Thanks to all that replied.....
Craig
   / Shallow Gas Well Drilling & Water Wells.... #13
Craig,
Here's a real good resource for gas well drilling in PA.
Natural Gas Forum For Landowners - Index
There is a lot of good info here - plan on spending a couple hours reading all of the old posts. As already suggested, get a couple of water well tests prior to drilling and then shortly after (<3 months).
-Dave
   / Shallow Gas Well Drilling & Water Wells.... #14
When reading online, or most other places as well, be selective in what you believe. Identify the state agency that regulates drilling activity in your state because their duties include protecting your groundwater. http://oilandgas.ky.gov/Pages/Welcome.aspx Their regulations will most likely include a minimum depth for the surface casing - the most important factor. Most likely that state agency will also have a public information office that will help educate you.
If you get your well tested, consider using a professional to both take the sample and have it tested. Then you have an unbiased witness that can testify as to the quality of your water before the drilling activity started.
Be wary of getting all worked up over propaganda such as the film Gasland. Yes, accidents happen, and it is possible your groundwater will become contaminated from the drilling or production activity. But if you look at the huge number of wells drilled in Louisiana, Texas, Kansas and Oklahoma, that risk is minuscule. Probably a lot less than the risk of driving to the local market to buy eggs and milk.
Most of the groundwater contamination comes from leaking refineries, UST's, and pipelines carrying liquids, not from gas wells. If you are concerned about contamination and live near a gas station, read up on UST's (underground storage tanks). In the 60's the state inspector told me that almost all UST's in Oklahoma leaked fuel to one degree or another. Since then the feds have passed stringent regulations that have significantly reduced that problem.
   / Shallow Gas Well Drilling & Water Wells.... #15
Craig:
Like several posts just above are talking about there have been a really lot of wells drilled over the last 40+ years in the Ohio/Pa/NY areas and so far none have been proven to have caused ground water issues from all the data I have read/looked at. That gasland show seems to be a real good ploy by the sand bearing countries to keep us hooked on Oil and to not use the natural gas we have at hand...
My dad had a gas well put in back in the late 40's or early 50s at the farm which hit HIGH gas pressure and could not be capped for almost a month until pressure dropped enough to be able to safely cap it. It is still producing today even though there is houses built all around the area the farm house still has free gas and gets a royalty check for the family. (none to me but Pop has been gone a year and his wife is getting that as the farm was broken up be they kept the mineral rights ;)
here is a link to our vertical/horizontal drilling rigs we build (Company I work for) http://www.americanaugers.com/www/docs/183
That chesapeak link was pretty good. thanks
Mark
   / Shallow Gas Well Drilling & Water Wells.... #16
All States that I am aware of are especially careful of protecting groundwater producing zones. They have strict rules about setting what is called surface casing thru those zones. Surface casing is cemented in place before drilling is begun for an oil or gas well. Once protected, there is little chance of a groundwater pollution problem. geologically speaking, the groundwater is separated from oil/gas producing zones by layer upon layer of rock and shale formations below. I seriously doubt you have anything to fear.
   / Shallow Gas Well Drilling & Water Wells.... #17
Search for well contamination dimock pa. Cabot, they are saying, used faulty cement, and caused methane to release into peoples water. Now some of the old folks living there have said its been there since the 1800's. Not sure just something worth checking out.
http://wcexaminer.com/?p=20368
   / Shallow Gas Well Drilling & Water Wells.... #18
It is not uncommon to find naturally occurring methane gas in ground water.:D
   / Shallow Gas Well Drilling & Water Wells.... #20
I am in KS. My in-laws had a gas well on their property and they had to share the royalties with 2 of their neighbors. I expect the PA. laws are different but it might be worth looking into. Oil was different, if the well was on your property the royalties all belong to the property owner. As far as water contamination there was none that we are aware of. There are some springs with in 1/2 mile on that property also and the spring was unaffected. I believe the "get a lawyer" advice was good.
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2005 TerraGator 8104 (A53473)
2005 TerraGator...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
