Sharpening...
   / Sharpening... #1
Rowski
Veteran Member
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
I need to sharpen my Valby chipper blades. The blades need to be sharpened at two angles. I really hate to go out and buy a special sharpener just to sharpen my chipper blades once a year. I was wondering if I could use my table saw with a grinding wheel? Or possible making a "jig" for the bench grinder that is adjustable? Any other ideas or thoughts? I sharpen my mower blades "free hand" and seem to come out pretty well. I think the chipper is a little more sensitive to the angle and how consistent it is.
Any comments or suggestions welcome?
   / Sharpening... #2
I was just planning on taking my chipper blades to a sharpening service. I bought a second set so that I can keep working while the other set is out.
-david
   / Sharpening... #3
A conical disc sander with a neat fixture to keep the blade at the 'angle' would work well. Another is to use a strip sander with a strip for metal sharpening. Again, using a small fixture to maintain blade angle.
   / Sharpening... #4
I finally decided to take the 3 small chipper knives from my Bearcat C/S to a PRO. They do a lot of woodworking planer blades. My blades came back perfect. They looked like brand new. They have the knowhow and equipment to do the job right.
Chris
   / Sharpening...
Chris
That's most likely what I will do. There is a machine shop sort of near by. I'll give him a try. Also will get the second set of knives.
mrcaptinbob
I have used the sanding technique on lawn mower blades. Works most excellent. My chipper knives are going to be in pretty poor shape and will to have quite a bit of material removed.
What do most of you use as a guide line to sharpen your knives? Is there a way to tell by the chips or do you just do it at a certain time interval. My manual just says to sharpen when dull.
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
