Shear Bolts, What do you Use?
   / Shear Bolts, What do you Use? #1
MrJimi
Elite Member, Rest in Peace
NorthEast, Florida
Case 1845 C Skid steer
I just recently purchased a Howse model 500 RC ( 5 Foot / 45 HP gearbox )and it came with a grade 5. 1/2" shear bolt, this seems to be a little heavy for this unit. What are you running and on what implement for your safety and is it heavy enough or could it be heavier or lighter?
I am running mine hydraulically and I could go with a relief valve in-line.
Darn I wish I could make a poll out of this, oh-well
Jim
   / Shear Bolts, What do you Use? #2
I have a King Kutter 5' with 40 HP gearbox, and directions say grade 2.
   / Shear Bolts, What do you Use? #3
Grade 2...
   / Shear Bolts, What do you Use? #4
Im gonna have to cast my vote for grade #2 also :)
   / Shear Bolts, What do you Use? #5
I have an old JD that I have to use a grade 5 7/16 bolt in.
A grade 2 breaks before it will get blades turning.
   / Shear Bolts, What do you Use? #6
Grade 2 or 3 at half inch dia. with mine which is 6' and rated up to 45 HP PTO. Used a grade 5 once and hit a rock. Made the worst racket and bogged down the engine a little but the bolt held - should have snapped it off like a twig. Ever since then I use the lower grade stuff out of the bins at Lowe's which is rated no higher than 3.
   / Shear Bolts, What do you Use? #7
In have two 5 foot cutters one (agrifive ?) use a 7/16 grade 2 the other (Woods brushbull) a 1/2 inch grade 2. I only have the manual for the Woods and it states "1/2" NC x 3" grade 2".
   / Shear Bolts, What do you Use? #8
I know this isn't about snow blowers but that is what I have a major problem with shear bolts with. It is a Ber-Vac 64" and when I run grade 2 pins they sheer pretty much as soon as I start blowing snow. I up graded to grade 5's and even they will shear when I hit clumps of semi frozen snow. I don't want to even try grade 7's but I get sick of carrying a pocketful every time it snows. Any ideas???
   / Shear Bolts, What do you Use? #9
I have a Howse 500 as well. I have been using Grade 2 but I snapped 3 of them today from hitting rocks and small trees. I can understand the rock snapping it but it seems like it should have made it through the small trees (1-2"). I know several others on this board have mentioned using Grade 5 bolts and I may give this a try.
Do you have a slip clutch on your cutter? If so, Grade 5 is fine.
It should also be noted that the Howse Documentation lists a 1/2" X 3 1/2" BOLT NC GR5 HHCS ZINC for the shear bolt. They actually recommend a Grade 5. You can see the exploded parts view at the following link. Click on Z62, which is the shear bolt.
http://www.howseimplement.com/html/300__350_400__500.html
I should also mention that someone borrowed our rotary cutter and replaced a snapped Grade 2 bolt with a Grade 8 bolt. Needless to say, they ended up replacing the gear box.
1573 (A54756)
1573 (A54756)
2011 Toyota Camry (A55758)
2011 Toyota Camry...
2011 INTERNATIONAL PROSTAR (A55745)
2011 INTERNATIONAL...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
2019 CATERPILLAR 226D SKID STEER (A52705)
2019 CATERPILLAR...
