shear pin vs. slip clutch on a brush hog
   / shear pin vs. slip clutch on a brush hog #11
Gary,
My cutter of 4 years has a shear pin. I thought about a slip clutch, but for no certain reason decided to go with the shear pin.
Don't know much about electronically engaged PTOs, but I engage mine at slow idle...and seems to engage pretty smooth. Even (unintentionally) trimming rocks and saplings too big for the cutter, so far, the tractor engine will die before a pin shears. Have never broken a shear pin, but with pivoting cutter blades, have never had the blades stopped cold, either.
I bought a shear pin model, even though I was a bit reluctant to go that route. But now, am not nearly as concerned that I gave up much by not getting a slip clutch.
OkieG
   / shear pin vs. slip clutch on a brush hog #12
Yup, the 855 doesn't have the electric pto engagement, does it?. On the 000's it really kicks in hard!
   / shear pin vs. slip clutch on a brush hog #13
Rockyridgefarm brought up a good point. Our DK45 has an electric engaging PTO. Last year I borrowed my neighbor's 6 foot rotary cutter because we didn't have a mower yet. While engaging the electric PTO, we must have snapped 6 or 7 sheer pins. The engine was kept idling. The extra time removing the pins and driving to find new ones was a pain. Some pins came out easy and some didn't. I purchased several grade 2 and ten grade 8 for worst case. The grade 2 snapped like dry spaghetti. The grade 8's lasted to the end. We didn't sheer a pin while mowing. We returned the rotary cutter with several spare sheer pins and my neighbor said that the original one had lasted him 6 years. The Mrs. mowed and I changed the sheer pins. The one good thing about the situation was that she agreed to get a mower sooner than later. A final thought, you could always add a slip clutch later.
   / shear pin vs. slip clutch on a brush hog #14
</font><font color="blue" class="small">( The grade 2 snapped like dry spaghetti. The grade 8's lasted to the end )</font>
Yikes.. I wouldn't use anything other than a grade 2 as a shear pin... If you used a grade 8.. sounds like somehting in the tranny might be weaker.. /forums/images/graemlins/ooo.gif
Soundguy
   / shear pin vs. slip clutch on a brush hog #15
</font><font color="blue" class="small">( The elecrically engaged ptos sure can snap a shear pin! )</font>
Even if you reduce rpm you are still getting cut pins?
Soundguy
   / shear pin vs. slip clutch on a brush hog #16
Dunno! I have a slip clutch!! I heeded the warnings from my fine tbn buddies!
   / shear pin vs. slip clutch on a brush hog #17
On my old mower i broke a few shear pins, then the mower twisted up like a shinny can...
   / shear pin vs. slip clutch on a brush hog #18
Soundguy,
Yeah, they would sheer within a few seconds after engaging. The First Choice RFM behaves differently. The startup force seems to be taken up by the belts. Sometimes they will squeak for a second until they grab. The tiller has a slip clutch and engages smoothly - I can't detect any slip.
   / shear pin vs. slip clutch on a brush hog #19
I just can't imagine a pto that is designed to engage like that.. seems backwards. That's why I like 2 stage clutch setup instead of independent pto... I can use my foot to engage the pto slowly if I want to... Seems like every time somethingmoves ahead in the favor of progress.. they are also taking a step back as well.
Soundguy
   / shear pin vs. slip clutch on a brush hog #20
It's not the independent PTO per se - it's the head-in-the-sand engineering behind the user interface. The 5000-series ag JD's (and I'm sure most other larger tractors) have fully independent PTO's but they have a by-gosh mechanical (gads!) lever i.e. hand-clutch that let's you ease in the load just fine. The only two possible advantages of the electric-switch units I can see is 1) they are easier to incorporate into an overall 'operator presence' system (read lawyers doing the engineering) and 2) I suppose they do make it easy to slap the PTO off in a move-quick situation. Otherwise IMO they bite.
Tim
84in Grapple Rake Loader Attachment (A56857)
84in Grapple Rake...
1994 International 3800 Bus (A54814)
1994 International...
Bean 25RC 500 Gallon Air Sprayer (A57148)
Bean 25RC 500...
2008 CAT D6T DOZER (A58216)
2008 CAT D6T DOZER...
3-5TH WHEEL PLATES (A58216)
3-5TH WHEEL PLATES...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
