Shibaura D23F Parts, Clutch, etc
   / Shibaura D23F Parts, Clutch, etc #11
I think I may be able to supply you with a ring /pinion. It may require a couple extra small parts & possible some machining.
Unfortunately, it's the rear ring thats blown. I'm ready to give up, I have split the tractor, but really don't relish digging much further into that rear end/transmission to swap parts. I'm pretty fair at swinging a wrench but you can't get much deeper into one than this. Lens and Buck (Buck, I was the guy talking with you about this on the phone a couple weeks ago), thanks for the help and advice.
Having run through all this, I don't blame Shibaura for this, it really is a very well build tractor, with a bunch of features that you can't touch on the new ones. Built in hydraulic tilt, nicely arranged controls and (litteraly) more gear choices with the splitter combinations than I can remember made this a pretty cool little rig. I worked it pretty hard in the time I had it, moving somewhere around 15 truckloads of fill in the course of backfilling and building up areas around my house, maintained and plowed a half mile of driveway and moving a bunch of building materials. Even now, it doesn't owe me anything.
One hint to anyone buying one of these (or any other Japanese grey I guess), make sure the bellhousing is free of water. These guys are worked in deep water in rice patties in Japan, mine had a couple cups of water in the bellhousing. This caused the clutch to rust to the flywheel, freezing them up when the tractor sat for a few months. It wouldn't disengage with the clutch pedel depressed, I stamped on the brakes a few times trying to get it to break loose. In the process of abusing the rig like this, a tooth broke off the ring. Hopefully someone else can learn from my mistake.
   / Shibaura D23F Parts, Clutch, etc #14
If it would help, I have an address of a Shib dealer in New Zealand that I have ordered parts from. I have a parts manual for D24F if any of the parts will swap.
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2017 Bobcat MT85 (A50123)
2017 Bobcat MT85...
(INOP) LONG 2260 TRACTOR (A51247)
(INOP) LONG 2260...
Generac Generator (A51691)
Generac Generator...
Valvoline 80/90 Gear Oil (A53117)
Valvoline 80/90...
