Shipping Containers and Tornadoes
   / Shipping Containers and Tornadoes #11
If you bury it, it won't fly away, but it can fill up with water and it can rust through in a few years. Plus, you still need a door on top, and one that won't let water in.
Containers are EXTREMELY durable. Much, much stronger than trailers and not likely to collapse during a tornado, but a twenty foot one probably only weighs about 4,000 lbs. and has a lot of surface area, so they could get blown around. Remember, they get filled with thousands of pounds of cargo and stacked many high on ships that take a pounding all the way across the Pacific. Sometimes a large storm will tear off a stack and they'll float around at sea for a long time. Yours would definitely need to be anchored down and the mounting system provided at each corner is more than strong enough for any assault by weather. You'd need to fix some anchors into a concrete slab. This could easily be done with heavy steel embedded in concrete and sticking out next to each corner where it could simply be welded or bolted to the brackets on the box.
In my area, permanently mounted containers are considered real property and are taxable :mad:, but, if just sitting there, are not.
The door latches/dogging system on them can't be beat for strength, but must be worked from the outside. If I wanted to weather a storm "in" one, I'd make a steel hatch that I could reach through to release the door dogs, or squeeze through in an emergency. Probably 16 or 24 inches across and released from inside.
Set up in this way, anchored sufficiently and with a hatch, it would be the first place I'd go in a tornado. And it would last indefinitely outside. Especially if you coat the roof with trailer top coating and paint the sides to prevent rust. If you still think that's not enough you could wrap retaining wall/corrugated plastic material around it and backfill a berm all around it. That would let the surface breath and still lock it in place like burying it. If there is any chance that water could rise in your area, keep the hatch up high so you don't get trapped, or put it on top. Something like a ship hatch with dogs. Maybe a periscope so you can watch the proceedings. :laughing:
   / Shipping Containers and Tornadoes #12
Bury it, tile around it and install a sump pump to handle water. Put a hatch in the roof. You could even pour a patio slab on the roof for everyday use. I suppose if you bury it right next to your home you could put a full size door in the side, in addition to the roof, so you could enter it from inside your home so it could be used for other purposes. But tile and a sump pump are essential in most places. Remember that '57 Plymouth that was buried in a concrete vault and was deep in water:
http://www.allpar.com/history/auto-shows/time-capsule.html
   / Shipping Containers and Tornadoes #13
Oh, I don't know about that. Here are the problems I see. 1) Containers have thin walls. If it is above ground, the wood and other junk flying around would go through those walls like they were made of paper. 2) Burying a container would be cool. For about 3 years. Then the metal walls will start falling apart. The containers hold up pretty well to salt water spray because they are coated and painted. But that only lasts a short time. I have seen some fairly new containers (less than 5 years old) that look in pretty bad shape. It usually means they have spent a lot of time on a ship. Bury one and the ground will just eat that metal away. 3) I think you could make it work. But you would need to bury it, so it won't blow away. Then have it coated with something (I wonder if Rhino lining would work). And I mean you would have to coat every square inch, top-bottom-sides. Then you would have to work out the entrance/Exit. Then some type of air vent system (pretty easy). Then a bilge set-up for the water.
Kinda seems like buying one of those plastic ones would be cheaper.
I want one of those safe-rooms. Soon as my lottery ticket comes in........
   / Shipping Containers and Tornadoes #15
Containers can be easily penetrated by flying objects. They are made from thin sheet metal. You would have to bury it or reinforce it with metal plates or concrete panels. You would have to also modify the door so it opens inside.
   / Shipping Containers and Tornadoes #16
There was a recent story about a trailer park in Alabama that bought a schoolbus and buried it with a backhoe. They vented it out the top and ran lectricity to it and used it as a community storm cellar for nearly 50 people but lass than $500.
Personally, we live in oklahoma and have a steel safe room. It made with 2in square tubing and 1/4in steel skin. Its bolted to our slab foundation with 3/4in diameter bolts and covered by our brick veneer. The door has 4 hinges and then 3-1 inch round-bar slides as locks. My wife still doesnt trust it and wants to hide in the 36" tinhorn in our driveway if a big one comes.
   / Shipping Containers and Tornadoes #17
I think OZ was safer than Kansas
   / Shipping Containers and Tornadoes #18
A friend of mine said that lots of folk around him are using them to make under ground shelters. The dig them in or mound the dirt up around them leaving the door facing East. Then they leave one of the doors buckled from the outside so it is very secure and just close the other one from the inside and secure it with 3 or so of the old fashioned dead drop board or pipe just like the old castle doors from the inside. They also go inside and make another wall and door as a double safety. They stock it with all the necessities or a bedroom including couch and television and even bathrooms, including an HVAC unit . Whenever they have tornado warnings at night, they just go out and sleep in their shelter.with all the comforts of home. To prevent rusting, they put on a thick bitumastic coating prior to mounding the dirt. They should work really well for folks who have a hill and can bury it at least 3/4 of the way to the top and leave an east facing door.
   / Shipping Containers and Tornadoes #19
Gary,
That makes a lot of sense. Too bad they have to live with that threat!
   / Shipping Containers and Tornadoes #20
If the container was not buried, or mostly buried, I would not trust it in a storm. Ties down would have to be very heavy duty. At least cable not straps.
In the tornadoes that hit NC last April, a coworker's family member was killed when a twister hit her house. The house was on a block foundation and had strapping every couple of feet. I don't know if the house was a double wide mobile home or a modular but I was impressed with how well it was built as we tore what was left of it apart so it could be hauled off.
The twister hit the front part of the house, which rotated over the second section. You could see where the either the roof ridge or wall/roof hit the ground. The second module was flipped over as well.
The metal strapping, I think it was over an inch wide, snapped in half. It looked like the twister first lifted a corner of the module, a strap failed at that point, the house lifted more, a strap failed, etc. The strapping failed like undoing a zipper. I don't know the holding power of that strapping but it took some oomph to snap it. I wonder if the house was tied down with cables if it and the woman would have survived.
One day I hope to build a storm shelter/beer cave. Our house is on a slope so I could trench out a spot, drop in gravel for drainage, and build a shelter with a permanent wood foundation, and use the trench spoil to mound up around the shelter. A door would be at grade for easy access. To use metal it seems like you would have to handle the water and water proof the exterior to prevent rust.
Later,
Dan
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
Informational Lot - Shipping (A56438)
Informational Lot...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2015 CATERPILLAR 815F2 SOIL COMPACTOR (A60429)
2015 CATERPILLAR...
