Shop almost done!
   / Shop almost done! #11
Thanks, Egon... amazing! I bet they take a bit of practice. /forums/images/graemlins/smile.gif
Bob
   / Shop almost done!
Clarification: the ceiling has already been sheetrocked. At 14 feet high, there was nothing in my garage that was high enough to get me up there. So I hired some fellows with scaffolding and had them do the high work.
Got 90% of the wiring done today; just have to connect the 220 lines to the circuit breaker box. Also got all the wall insulation done. So any time now I can bring my shop tools back from the garage and use them to help finish things up inside.
The only sheetrock I have to do is the walls from the topplate down. But all those cutouts for outlets, windows, etc will be a real challenge! Any tips for getting the holes where they are supposed to be?
Pete
   / Shop almost done! #13
<font color="blue">Any tips for getting the holes where they are supposed to be?</font>
I've had good luck measuring to where the center of the box is, plunging a Rotozip like tool into the box, then using the edge of the box as a guide to cut the drywall.
   / Shop almost done! #14
Smart Man. Wish I had good advice about the cutouts but mine always turn into a disaster.
Egon
   / Shop almost done! #15
Rotozip type tool is what the pro's use. Plunge into the middle and go to the edge, pull out, and go around the outside edge. Metal boxes work the best, the hard brown plastic take a little practice and the blue plastic boxes are very hard to feel around.
BTW if your hanging the rock on ceilings by hand using your head I get a better feel using a ball cap but first remove that little button on top!
Patrick
   / Shop almost done! #16
There is a rotozip bit that is designed for this. The tip has no side cutting action so it can guide around plastic electrical boxes without chewing them up so bad. Be sure that the wires are tucked in nice and deep in the boxes.
The pros that did my house didn't even meaure a lot of the boxes or maybe only measured in one direction from the edge of the sheet. Eye-ball guestimated the location, plunged into the center, found the inner edge, jumped over to the outside and went around the outside.
They did use some nails, but only a couple per sheet to hold it up until they could put the screws in.
Their procedure was: Measure and cut the sheet for length (and width if necessary). Measure the stud locations and mark. Start two or three nails on the upper edge of the sheet at the stud locations. Lift the sheet against the wall and hold it there with one hand while reaching up and hammering the nails with the other. After the sheet was in place, zip in all the screws with an auto-depth drywall driver. They used corded drills and didn't stop spinning them, even to put the screws on the bits.
For the walls, they put the 12' sheets horizontally. They did the top sheet first to get it tight to the ceiling.
They did the windows in a similar fashion - nailed the rock up loosely over the window, zipped around the outside, and then screwed it down tight to the wall.
- Rick
   / Shop almost done! #17
Yep , the GP-10 bit. roto-zip That is a very easy way to do the cut-outs.
   / Shop almost done! #18
</font><font color="blue" class="small">( Any tips for getting the holes where they are supposed to be?
)</font>
Pete,
Sounds like it's coming along great! May just have to plan another trip out to Vermont to check it out! /forums/images/graemlins/wink.gif
I agree with the other guys about using the Roto-Zip tool. Works really slick. Another thing you could do that has worked for me in the past is to put some chalk, like from a snap line, onto the outlet or whatever you need to cut out for. Then place the sheet rock in position and push slightly against it to set the chalk on the back side of the sheet rock. That'll show you where you need to cut out. /forums/images/graemlins/smile.gif
   / Shop almost done!
That sounds like a neat trick! Looks like I have enough leftover siding to do one wall in wood...and practice with all the sheetrock I've saved! If I use drywall screws I can easily remove my mistakes and try again. Thanks for the tip!
Pete
   / Shop almost done! #20
Hey Pete, is the shop done yet?? Haven't recieved an update in awhile. You get snowed in or just head out for a warmer spot?
Sugar house is almost done!! Now all I have to do is figure out how to run that new evaporator!!!!!!! /forums/images/graemlins/grin.gif
Take care
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2002 Semi Deck Over Trailer (A50514)
2002 Semi Deck...
