Shop light advice?
/ Shop light advice? #61
texasjohn said:
hmm.... I guess I didn't find the good deal on the PAR 38 LED bulbs....
Place I looked has them for $60 each and they put out 200 lumens... don't think that will do what I need... too much money, too little light.
You can look on ebay or direct thru LEDwholesalers.com.
LED Wholesalers (Powered by CubeCart)
The lumens are lower, thus the gross of bulbs!
Steve
/ Shop light advice? #62
For my new shop, I ended up purchasing Lithonia I-Beam series T5HO florescent lights. They were expensive at $160 per fixture, but that does include bulbs. I have 15 of these things to hang, so you can figure the amount of money I spent. Ouch! All but two of them are the four bulb fixtures. In my welding room where I want more light for set up, etc, I’m using two six bulb fixtures that were just under $200.
For those who aren’t familiar with T5HO bulbs, they are fairly new. The bulbs are 5/8” in diameter and typically 4’ long. A four bulb fixture only draws 230 Watts but each bulb puts out 5000 lumens. A four bulb fixture is designed to replace a standard 400 Watt Metal Halide fixture. The key is they are the only florescent lights that are bright enough to use in a high-bay application.
The reason I’m using these lights is they are instant on where as metal halide take a few minutes to come on, have extended temperature range ballast, are wet location rated (so I can put them under my shop awning) and are the most economical fixtures available.
It was a lot of money to spend, but this is the last shop I’ll ever build. I’ll post some pictures in the coming weeks when I get all of them hung.
/ Shop light advice? #63
Correction on the pricing:
4 bulb fixture including bulbs - $143
6 bulb fixture including bulbs - $178
Still ouches a little though...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A65563)
2002 Ford F-250...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
