Shop Vac Suction at Hydraulic Fill Port?
   / Shop Vac Suction at Hydraulic Fill Port? #11
I think it's an urban legend or only works on small SCUTs.
IMHO it's definitely a trick. I got tricked into taking a bath in hydraulic oil trying to change my M59 filters without draining the oil first. Never again.
   / Shop Vac Suction at Hydraulic Fill Port? #12
I've heard of the shop vac trick but never tried it myself.
One thing to think about is that the trans/hydraulic reservoirs is probably vented to the atmosphere - most of them are if not all. So that venting will limit the vacuum that the shop vac can pull. It's one one more thing making it difficult to suck oil into the vac.
rScotty
Trans reservoir vent opening plus drain hole opening then if hyd filter is loosened all these openings added together making it even more difficult for a shop vac to create enough suction added to the weight of hyd oil to raise hyd oil enough distance to reach tip of suction hose!!
Shop vac would require enough suction to be able to suck a 3/4'' ball through a garden hose.
   / Shop Vac Suction at Hydraulic Fill Port? #13
Worked for me, wife held the shop vac, while i changed the filters, still lost some fluid, maybe half a quart. Got to take my time, as I was worried if I hurried I'd cross thread it.
   / Shop Vac Suction at Hydraulic Fill Port? #14
It's worked great for me. I crawled out from under the Kubora L4060 & ended up spending minutes looking for something with a full hydraulic sump & the filters off. The shop vac only let a couple drops out.
The biggest problem is keeping the vac attached. I taped my hose on & it held, barely. A 2nd person would be ideal, but tape works. Pure suction may be iffy in many cases.
   / Shop Vac Suction at Hydraulic Fill Port? #15
on the kubota grand L series the transmission case vent is in the fill cap so you get a two for one. I don't know if there is another vent else where. Never did try it though but I plan to in about 30 hrs . Due for just HST filter soon.
   / Shop Vac Suction at Hydraulic Fill Port? #16
I have the same experience as Fallon. It works flawlessly.
   / Shop Vac Suction at Hydraulic Fill Port? #17
I change or clean my hydro filters at the 300 hour mark when I change the oil. I never do the filters before the scheduled maintenance interval.
   / Shop Vac Suction at Hydraulic Fill Port? #18
I would worry about the shop vac overheating but that is apparently not a problem. Would think that no cooling air moving thru the vac would build heat?
Air through the vac chamber isn't the problem, meaning the restrictions through the transmission/hydraulic reservoir isn't likely to harm anything about your vacuum. The air through the vacuum reservoir doesn't go through the motor unless you have a very poorly built vacuum. That's why most of them have vents on the top, and a separate discharge for blowing air. There are also vents down near the lid, where air is drawn in and blown through motor. The float/check valve is to keep liquid out of the fan which could affect the bearings as well as throw a rather high speed fan out of balance. THAT's the problem, but I would leave the foam primary filter on just to give that little dab of insurance. It's what I do when I use my cheap vacuum for picking up water. There's basically a tornado inside that reservoir, and a lotta splashing going on once there's more than about an inch of liquid in it. First time I saw water spit out the discharge, and the vacuum started walking around by itself, I was convinced the primary foam filter would remedy that. It did. There's a diverter on the inside of the vacuum side to make sure all liquids go down away from the fan. It isn't an oil tight or water tight seal, but the last thing you want is damp/dirty air from the inside of the vacuum going through the motor. It won't last. If you see moisture around the motor cooling vents, you've likely spun the bearing for the fan in it's usually plastic mount, and it's time for a new vacuum.
If you have other vent holes on the tractor (case vent), including when you remove the suction filter (the worst one) all it can do is draw air into the transmission. I would be extra cautious about making sure the area around the filters is clean to make sure I didn't pull any dirt/moisture into the oil I'm trying to save. If it isn't enough vacuum to hold back the oil, then pinch off the case vent with a clothes pin or small clamp.
As for burning up or overheating, probably not going to happen. In the first paragraph, note I said the motor doesn't need the suction fan for cooling. The fan (drive end) bearings are sealed high speed bearings. Good to go unless your vacuum is as ancient as mine. Never need lubricating, which is a good thing because they're sealed anyway. Mine howls a little when I turn it off. That's your sign you're gonna need a new one soon. The motor has MORE load on it when the fan is actually moving air. The more air flow, the heavier the motor load, the hotter the motor gets. Shut the air flow off, the motor current decreases, the motor speeds up (supplying more cooling air to itself) and will likely run that way for ever. If the motor starts overheating, it's likely because dust/debris has fouled the cooling air path. It was gonna overheat anyway. Again, your sign that it's time for a new vacuum, or if you're mechanically and electrically agile, time to clean it really good. You're not likely to find parts for cheap vacuums, though, and if you do, it'll probably be cheaper to replace the vacuum.
But, considering the time it takes to get things cleaned up, the vacuum attached, and someone to hold it, I can have the two drain plugs out and the fluid drained into a CLEAN catch pan so I can have a look and make an educated choice about replacing the fluid or not. No drips. no drops. I'm not saying it's the best way, because I have to funnel it back in if I'm re-using it. It's just the way I prefer.
IMHO it will require very powerful suction of a shop vacuum to suck oil from hyd reservoir on a tractor unless oil level is way above reservoir full mark especially if the drain plug is absent IE removed
All good replies - thank you.
The goal isn't to actually pull fluid out, but put enough suction on top of the fluid to offset gravity.
It sounds worth trying, and my shop vac isn't new so worth the risk of it ingesting oil.
A lot of people use this trick without problems. It's not going to suck up oil as long as there is an air gap.
All I ever do is block the breather vents on the hydraulic system. That is enough to minimize fluid loss on my Kubotas. No shop vac needed.
Are you thinking to leave an air gap at the fill port, where the shop vac hose would be? Or to leave the breather vents open? Where are those on a Kioti DK40 SE if you happen to know?
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
