Buying Advice Shopping Advice - Small L's
   / Shopping Advice - Small L's #11
Re: Shopping Advice - Small L\'s
Very good answers, Muhammad, but I'm betting Harv's going to buy one those smaller used tractors, and within a year trade up to bigger, new one./w3tcompact/icons/wink.gif Of course, since he's shopping carefully, he may get his money back on the used one when he does.
Bird
David, Muhammad, Bird -
Your comments and feedback are of great value to me. I never thought of a message board as a support group, but it sure as heck is. /w3tcompact/icons/smile.gif
I can't help but notice that nobody is trying to talk me out of buying a smaller tractor. Part of me is disappointed, but I think a greater part of me is relieved. I might just stay on budget after all. That would allow me to pick up some nice implements sooner rather than later. And if I step up in size later on, I still have the nice implements, right?
I have one more day to think it over, and then maybe I'll be making the decision. It all sort of hinges on how the nursery tractor checks out.
   / Shopping Advice - Small L's #13
Well, Harv, I would say do what is comfortable to you! I bought my old L175 (turns out to be an L1500) to puddle with, and though its not super fancy, nor medium fancy, it does what I want it to do, and I am comfortable with it. No-one has turned their noses up at me, and the best of all, its paid for and Orange!
   / Shopping Advice - Small L's #14
It's kind of scary but hours don't always tell the tale. I've seen low hour tractors in duty as rentals that I'd be scared to buy. Also seen some higher hour units that may last for years and years. One of the fellows posted a link to a site that had "what to look for in an excavator." Are there any books Harv could get that would help in this regard? Take gas engines, your typical listening for knocking and compression testing and listening to the tailpipe sure doesn't work for a diesel!
I'd suggest getting on the internet and forming a circle searching list of dealers, NH JD and KU fanning out from your location, contact them all. They may have what you need. If you are fixed on Kubota only, still do it as trades come in. Last time was in the JD dealer in Sumner Washington they had a small Kubota. I see this mix of colors in the back lots of all dealers. Try to let them know what you are looking for, and ask them to keep the info. Sometimes they will make a deal with someone if they think they can sell the trade to you. Boy 42 acres, I wouldn't go less than 30 gross hp unless it is just mowing you have to do.
And even going by HP is getting tough. I have a 35hp and a "22" hp BX for my 10 acres. I use the "22" as Kubota is doing what GM and probably others are doing, figuring HP at some higher rpm. On a tractor or even a pickup who gives a rat's axx what the hp or torque is at 4000+rpm. Chevy salesmen are currently running off at the mouth about the 300 (now 320hp) 6L engine. A nice engine, but all of their engines now have torque peaks way the heck up into an area I'd never be using. Look at old specs for the 5.7. Kubota has done this with the BX, I'd consider it more equivalent of the old 18hp, as I'm probably never going to run it up to 3200rpm to find the extra 4 hp. I wish the FULL torque and hp specs were published, including a graph showing when you get what.
Are you also doing a search of all the "nickel-ad" papers in your area? For instance when I type in "nickle-ads" I can get a combined listing of all the typical local-free-in-the-store ad papers for WA OR ID. Then there's the truck and heavy equipment trader magazine. I'd also suggest putting up a big WANTED poster on the local feed store bulletin board, or even a "WANTED AD" in the paper or on line.
   / Shopping Advice - Small L's #15
I have an L2500DT. Use a 5ft bush hog through 3ft bush/scrub growth with no problem. (Manual actually rates it for up to a 6footer). Your 14 inch boulder ia WAY too small. I move much larger ones than that. My only limiting factor seems to be being able to fit it in the bucket! Your log skdding shouldn't be a problem. I have a 5ft box blade with 350lbs extra weight loaded on it to help it dig and I have no problem with pulling that. As mentioned previously your only problem could be the stump pulling part. If you have a tree and can hit it high with the loader BEFORE cutting it down you'll have a better chance of dislodging the stump but as far as just pulling the stump out forget it. A 5 inch stump has some unreal holding power if you just try and rip it out. I couldn't even pull out a 5 inch arborvitae until I starting wiggling it back and forth with the loader AND chopped some of the roots!! Re the hours on the nursery one they do seem really low but if it was only used to move things around it probably didn't run at PTO speed much so the hour meter runs much slower. I'd see if you can find out HOW it was used. Could very well have been some really light use. My only concern then would be seeing the service records
   / Shopping Advice - Small L's #16
Harv,
Rather than repeat, I'll agree with what has been said. I do everything you have mentioned, except pull stumps, with a 21 hp. Kubota. You just have to remember that smaller tractors take smaller bites. They do it, just not as fast.
Does the L2250 have power steering? My area is steep and tight and I would have to have power steering. My old tractor about did me in without it.
For what you have going I think the FEL on the 2250 is worth more than extra hp. If you found the bigger tractor, you would like, without FEL, it is a high dollar "add later".
Good luck and keep us posted.
   / Shopping Advice - Small L's #17
Harv, you're right about being able to step up in size later, and <font color=blue>still have the nice implements, right?</font color=blue> However, you might want to think seriously about the size of those implements though. When I bought a B7100, I expected it to last a lifetime, so I bought a 4' box blade, 4' brush hog, and a 40" tiller. Then last year when I traded up to a B2710 I had to trade up to 5' box blade and brush hog (and just can't afford to trade up to a larger tiller, although I would like to).
Bird
Good point, Bird.
I guess the message here is for me to get the largest implements that make sense for the smaller tractor so they won't look too puny behind a larger upgrade.
Very timely advice.
MarkV -
Good question. I don't know all the specifics about the machine yet.
Anybody out there know if power steering is standard on an L2250 4WD?
   / Shopping Advice - Small L's #20
I THINK the PS is standard on the 4 wd but not on the 2wd but I'm not 100% on this
1980 AM General M35A 2.5 Ton 6x6 Cargo Truck (A50323)
1980 AM General...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
