Should I Dump Almost 5 Gallons of Diesel?
   / Should I Dump Almost 5 Gallons of Diesel? #32
Someone message steveky to ask if the harmonics in his regulator were thrown off by the stabil, causing him to need new muffler bearings.
   / Should I Dump Almost 5 Gallons of Diesel? #33
Do you heat your home with #2 heating oil? If so, you could pour it in that tank if it makes you feel better and it won't be wasted.
   / Should I Dump Almost 5 Gallons of Diesel? #34
That's about as much as a Massachusetts politician is native blood.
Or....ten times the weight of Trump痴 brain...lol.
Sorry, hard to resist when someone has to inject politics into everything.
   / Should I Dump Almost 5 Gallons of Diesel? #35
Bottom line, you probably got worse out of the pump without knowing it.....
It will be fine, just run it.
I'm the original poster. Called Sta-Bil. Asked if there was anything in the stabilizer that could harm my tractor. He asked which color I used. I think he said red, yellow, or blue. I said red. He said no problem.
   / Should I Dump Almost 5 Gallons of Diesel? #37
Kind of what we all figured... :)
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
