Should i replace these pistons and rings (with pics)
   / Should i replace these pistons and rings (with pics) #21
What was the compression before tear down? Or did you just jump in head first into the engine?
Usualy black snoke is unburnt fuel. This can be caused by many issues. Low compresson, not enough air getting to the cylinder and many more.
Did you take off the exhaust manifold? Is the soot/black stuff mostly on one cylinder?
Alight so maybe someone at some point threw a few big CAT stickers on the machine. The engine is definitely Mitsubishi, ( Mitsubishi K3E 1.05L disel engine). The parts I ordered (rings and head gasket) fit as they should. I suppose I should shift my search to the engine and not the machine type for the service manual. Nyone I did not check compression before tearing down, a step which I am regretting. But all 3 cylinders looked to have about the same amount of carbon build on up them.
Ignore that, it's listed below the other types.
   / Should i replace these pistons and rings (with pics) #25
Get your self a bore gauge. See how out of round the cylinders are. Or put the head back on and do a leak down test.
   / Should i replace these pistons and rings (with pics) #26
Also get a micrometer to measure the pistons so you know if they need replacing. You'll need a shop manual with the specs. If you can't find one for your engine, often a similar size and vintage engine from the same manufacturer will have similar specs.
   / Should i replace these pistons and rings (with pics) #27
the pics of the pistons are way to large, a good reusable piston will have oil retaining ridges around the skirt of the piston, to chk
the cyl to piston clearance without instruments position the piston 1/2" down the bore correctly clocked as when running, use a narrow blade feeler
gauge and measure the clearance on 12 and 3 o-clock position at the skirt and divide by 2, most wear will be on the skirt.
if it was me i would replace the pistons.
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
