genusCastor
Maybe I'm to late but I would coat the whole spline area with never seize before you tighten everything up. It will be a lot easier to get apart the next time.
Yessir, done did. I put neversieze on errythang!
- djb
Hi Guys,
Wotza stump jumper??
Ian
...the rust pitted, saucer shaped object in post #1 of this thread...
I got the stump jumper off, and the spindle looks fine, no damage. I reassembled and tightened the castle nut down, and it will, in fact, secure the stump jumper. But the nut goes up above the cotter pin hole, so what I think happened is that the castle nut backed down to the cotter pin. Why they would put a cotter pin in below the castle nut...? Maybe they just didn't tightnen it down all the way to begin with.
I'll need to add a shim to get the castle tight tightened at a location where the cotter pin actually secures the nut. There are a couple shims on it already, I have a piece of 5/16" plate, might try cutting a washer out of that. Get to play with...er...ah...I mean use the plasma cutter.
I have the bush hog up on blocks, can get to the blade assembly easy. Might try the tilt method next time tho...
- djb
