Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,668
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I am very new to stick welding. Working on my 2nd 5 lb box of 6011. I did a little project to make my learning more interesting. Might be a ahead of my ability but nothing to lose. I have a roll around work/welding cart I built with my O/A torch that I use a lot. Once in a while I wish it had a brake so I made a fold down over the center leg for a brake as a stick learning project.
I used a piece of 1/2" hydraulic tubing with an .065 wall that I had as part of the hinge. I used a 3/8" bolt as the pin thru the tubing so it was a close fit. I did some practice welds with 6013 on the tubing and didn't burn thru but the diameter shrunk so much that I couldn't come close to putting a 3/8" bolt thru it. I ended up braze welding it to keep from deforming it.
My question is this - Did this happen because it was thin walled tubing or do all circular pieces shrink when welded and if so is there a way to predict how much the diameter of the piece will change when welded ?? I was afraid to weld it with the bolt in place in fear that it would never come out.
Thanks.
gg
Thanks.
gg
