Side grades with a grader box?
   / Side grades with a grader box? #1
MLB
Fort Wayne,IN (NE)
New Holland TC33D
I need to grade a property that abutts a farm field. The house is on a high spot tapering down to level grade all the way around. THere is a slight lip to prevent field water from coming onto the property. SO....
I need to work across this slight hill, at the bottom where that lip is, without destroying it or gouging out a line with the bottom edge of the box.
Is this where you would adjust the side attatchments of the 3 point to angle the box itself? I also come across similar situations with septic systems. Need to grade, but keep the the tapering.
New to this, but getting wet /forums/images/graemlins/smile.gif
Any help is greatly apprecitated! /forums/images/graemlins/crazy.gif
   / Side grades with a grader box? #2
I've done similar work by shortening one of the draft arm links and it worked pretty well. My work involved cutting a walking path into the side of a hill. As I mentioned earlier, it worked well, but it really would have been nice to have a hydraulic link. That would have mede the adjustments much easier!
just to be sure........if the right side is the low side I would shorten the LEFT side arm???????????
If I end up getting enough grading work I'm sure I'll have all hydraulics if not a power rake. The tractor has one set of remotes so I'd like a hyd top link first. /forums/images/graemlins/tongue.gif
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
