Sigma (Sicma?) tiller?
   / Sigma (Sicma?) tiller?
The seller says this one comes with a slip clutch, as does the one from Agri-Supply. I don't think I've seen a new one for sale anywhere that didn't come equipped with one.
   / Sigma (Sicma?) tiller? #12
I've heard you have to adjust the slip clutch models each year or they can seize up?
You heard correctly. In fact, you should probably adjust the slip clutch (15 minute procedure) if you haven't used the tiller for 2-3 months especially if it sits in the rain. If you use it consistently that is not necessary.
   / Sigma (Sicma?) tiller? #13
I had a Sicma 1066 rototiller. One of the dumbest things I ever did was sell that unit. They are very good rototillers.
I now have a Land Pride 2064. At 700 pounds it is a much tougher unit-it also costs about 3X.
I have a slip clutch on all my attachments except the flail mower. "Adjusting" the clutch is nothing. Just make sure the tension is about the same and it actually slips. It is a little more complicated then that but not much. In any event it sure beats carrying around a bag of shear bolts. That gets old real fast.
   / Sigma (Sicma?) tiller? #14
The Land Pride dealer (Case Ag dealer who also sells Land Pride) actually recommend the shear bolt model. He doesn't have either in stock so he's not trying to push one he has on the lot.
He didn't seem to think our clay soil around here wouldn't "shear" any bolts as long as you didn't slam the unit into the ground at full speed. He has had issues with "lazy maintenance types"---i.e. = me, not taking the time to adjust the slip clutch each year, and with rain outside or humidity in buildings causing havoc with slip clutches--can be an expensive repair.
I think I'm going the shear pin route--plus it's around $150 to $200 less.
The reverse rotation models really interest me the most. Dealer actually called Land Pride yesterday and they have many forward rotation in stock, but the reverse rotation models are moving off the shelves fast. He had called them for me to check the difference between the RTR1050 and RTR1250 models. If you look at the specs they are practically identical. Only difference is 4 pounds of weight and the RTR1250 only has a 3 year gearbox warranty while the RTR0550 and RTR1050 both have 5 year gearbox warrantys. Land Pride rep said they found a new company for the gearbox's on the 1250 models (new models for 2011) that is costing them much less but still an excellent gearbox. He said the 1250's are selling fast because they have passed their cost savings along to the consumer so the 1250 is the lowest priced unit between the 0550, 1050, and 1250. The 1250 does come with slip clutch only. I'm leaning toward the RTR0550 with shear bolt.
   / Sigma (Sicma?) tiller? #15
If you decide on shear bolt protection, better make good friends with the protective safety bell that covers the shear pin area. Ken Sweet
As it turns out the original question is academic because the craigslist ad has been deleted. He's either sold it or decided to keep it.
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
Toro Workman HDX-D Utility Cart (A55787)
Toro Workman HDX-D...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2017 KUBOTA RTV-X1120D (A54756)
2017 KUBOTA...
