Silly ag tire question
   / Silly ag tire question #1
bx24d
I just put a set of ag tires on my agco 2027 (27hp diesel subcompact) which I plan to use for plowing this year. Two questions: how bad do again tear up a hilly lawn when mowing? And, which way is the "v" pattern on the tire tread supposed to point? Forward or rearward?
   / Silly ag tire question #2
To answer your second question...
   / Silly ag tire question #3
If you take it easy on the lawn. No sharp turns you should be fine. The tires when looking from the front will point towards the ground. There will also be a arrow on the sidewall that says "forward". If you put the tires on backwards they will not drop the mud like they are supposed to. I have seen them on that way and they look goofy. A picture sums up what I just said best.
   / Silly ag tire question #4
Also if your tractor is 4x4 don't drive on the grass in 4 wheel and turn.
   / Silly ag tire question #5
Yeah
   / Silly ag tire question #6
Funny, I found the exact opposite with my tractor. If it's in 4x4 the front wheels help pull the front of the tractor around but in 2x4 it tends to push (understeer) which tears up the turf.
   / Silly ag tire question #7
I agree, at least with turf tires. But I do not know if that holds true with AG or R1 tires. Seems like it would. Though sharp turns year up the lawn no matter what.
   / Silly ag tire question #8
Ag tires are unidirectional...which means they're designed to get best traction when mounted a specific way. This is an attribute they share with R-4 Industrial tires. These types of tires have an arrow embossed on the sidewall to show direction of travel.
   / Silly ag tire question #9
For primarily loader work you can reverse the fronts. Said to wear better.
   / Silly ag tire question #10
I've never heard they wear better, but that is supposed to give better traction when backing out of a pile of materials.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
