simple trig help needed
   / simple trig help needed #21
There are many ways to approach this problem. The first answer given by James is correct for the given example.
Another method which does not involve trig would be to pick a spot on your side of the creek, point 1, and a spot on the other side of the creek, point 2, with the goal of determining the distance between point 1 and point 2.
From point 1 lay out a base line on your side of the creek that is 90 degrees to the line connecting point 1 and point 2 and move down this base line until the angle to point 2 is 45 degrees and mark this spot as point 3.
The distance between point 1 and point 2 will be equal to the distance between point 1 and point 3 on your base line.
   / simple trig help needed #23
also for your information sin cos and tan are also for right triangles only
   / simple trig help needed #26
I can do this with trig, but the dirt simple, no confusion, way is to keep walking down the creek until the angle to the point on the other side is 45 degrees. At 45 degrees, the two sides of the right triangle are exactly equal, and the distance across the creek is the same as the distance from your start point.
Alternatively, go buy a range finder. I have one that measures to 400 yards with +/- 1 yard accuracy. Not only does it work well in this kind of situation, it has improved both my golf game and my hunting...
(After looking over the other posts, I see that pillar has beaten me to the first method.)
   / simple trig help needed #27
Not if you know Law of Sines and Cosines...
sorry I had forgot about that also, usually I use a bit of geometry for non right triangles to solve with the simple equations. Actually I seldom use the calculator any more since my CAD software figures it out much faster then I. As far as using the trig tables that stopped 30 years ago. Thanks for reminding me about the old days.:D
   / simple trig help needed #29
Did everyone have those Air Force trig tables they handed out.? Now this was 40 years ago, but every kid in school had one.. Oh I also had a couple of slide rules.. 1 slipstick, and 1 circular one. Now you all know I have a long flowing white beard..:laughing::laughing: I bet if you handed a kid of today a slide rule he would not even know what it was.
James K0UA
   / simple trig help needed #30
:thumbsup:
I use a² = b² + c² 2bc cosA all the time. Dont have to worry about it always being a perfect right triangle. And it really handy when figuring dump angles and forces of things like dump beds/trailers, loaders, etc.
The law of cosines there is basically the SAME thing as the Pythagorean theorem. The PT just simplifies it for a 90* angle. Because the cosine of 90 is 0, it cancels out the whole 2bc CosA part of the equation leaving JUST a² = b² + c²:thumbsup:
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2014 Nissan Maxima (A50324)
2014 Nissan Maxima...
