Siphon for hydraulic oil....
   / Siphon for hydraulic oil....
Richard,
Which hoses connect to the cooling chambers? Are there hoses between the main reservoir and cooling chambers?
Tried to find schematic of them. Don't know if this is the best one or not....but here it is.
Looks to me like there are two circuits (??) One goes to center pump (for blades), then exits at 9:00 and goes to cooling tank. Next to that is another one that goes back, cuts left to go to left pump then goes to right pump in a serial connection.
The book I'm looking at I THINK has several mowers it deals with or, maybe same mower at different times.
I THOUGHT the pressure line went from one to the next to the third motor in a series but, this schematic shows it a bit different.
None the less, after the motor, (for the blades) it then goes to the tanks.
There are then some shorter hoses to connect the tanks on one side of the wing to another.
Not being an engineer, I DO think it's somewhat clever how they built the tanks into the unit itself.
  • Hose path.pdf
Buy a small 12VDC pump ( https://www.amazon.com/Amarine-made...8&qid=1545417772&sr=1-26&keywords=12+vdc+pump ) and drain old into a drum (I made a AG sprayer out of my pump which works well after you have used it to drain your mower)
Is there a filter anywhere in the system?
Also, is there contamination or some other compelling reason to change 45 gallons of hydraulic oil that only needs to lubricate bearings and gears. Sure, the old oil may have sheared down in viscosity but, who cares.
There are two maybe 10" tall filters hanging on the backside of the "tank" in the front of the unit.
There is another "filter" on the TOP of this same tank but I think it's just a breather cap. You take it off and there is another assembly below it that is probably vented to tank and, you need a wrench to remove that part (to then fill tank I presume)
The sight window is on the front of this tank.
Here's picture of actual mower (not my tractor though). You can see the filters on top and behind the tank on the front of the unit.
This isn't oil for the gears, it's the hydraulic oil that powers the pumps on the blades.
I had a hose crack other day and it looks a bit milky. Didn't get a great look at it..... might have looked lots of milky.
In the end it's one of those "I have no idea how much he maintained it so I want to start at a known (good) point"
   / Siphon for hydraulic oil.... #14
As for gears, I was referring to the gears in the pump (or possibly the vanes if a rotary vane pump). I am mechanically familiar with hydraulic pumps and motors. In the end, lubrication, cooling and corrosion protection are the main duties for the hydraulic oil.
Why not remove one of the filters and see what's inside?
Depending on the value of the mower and your desire to restore it and maintain it for reliable service, you may want to do a couple of UOAs after the new oil has been in service for awhile.
Drove into town today to get a couple hose clamps to hold the suction/supply hose to the reservoir and pump. Mower has NAPA filters on it.
Don't you know I got all the way into town 15 miles and.... forgot to write down the numbers!!!
put mower on a slope and siphoned more of the old oil out, certainly not all. Got some new fluid (20 gallons) at NAPA and put about 15 in. Took out for a test drive and it absolutely ripped the snot out of everything I drove over.
I'm really looking forward to spring. I totally enjoy cutting the fields, i find it very relaxing. Now I can do it with 15' behind me instead of the five footer that my wife's uncle used for decades. About 8 years ago I finally stopped cutting the place as it simply took too much of my time/life to cut land that didn't belong to us
(her father later bought an IH 886 (866?) and 10' Rhino mower.... so I went back to cutting the place to help out but his son sold it when he passed away so we need to get something again to cut the farm, enter this mower behind an IH 1066)
I won't be restoring it. I might paint it just to help protect it. Change a few hoses.... basic maintenance to keep it functional (and that's all)
   / Siphon for hydraulic oil.... #16
Looking at your unit, if you fold the wings up can you blow through the lines to get the old oil out?
   / Siphon for hydraulic oil.... #17
Sounds like you have already bonded with the thing...
After you're done with the oil change, why not pressure wash it, mask off the no paint areas and give it a coat of your favorite color.
I'm going to Jet Hot the exhaust on my M-F. Haven't decided on the color yet...
   / Siphon for hydraulic oil.... #18
To get the oil out, why not remove the return hose from the tank and place in a drum. Then crank the engine and let it pump the oil out. Cut pump off when it starts sucking air. Then remove suction hose from the tank and stick it down in a new can of oil and let it push thru the hoses until it runs out of the return. Button everything back up and refill tank with oil.
Kidd 450 Straw Chopper (A50774)
Kidd 450 Straw...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2015 Ford F-150 4x4 Crew Cab Pickup (A50323)
2015 Ford F-150...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
