Sir, what hydrualic fluid should I use?
   / Sir, what hydrualic fluid should I use? #1
hondarider
I own a Trex TX650 skip loader. Being a newbie, I called the Terex dealer in northern california (RGW Equipment Sales) and talked to a very nice gentleman to find out what type of hydraulic fluid should I use?
He told me to go ahead and use any 10w motor oil.
He also told me to use 10w oil for the brake fluid also.
Should I laugh or cry?:eek:
   / Sir, what hydrualic fluid should I use? #2
A lot of machines use lightweight engine oil in their hydraulic systems. Do you have a reason to doubt what they told you?
   / Sir, what hydrualic fluid should I use? #3
No, you should thank him.
Power-Trac machines use 10W-40 motor oil for the hydraulics, and my Case skid loader uses the same, with a quart of Case additive. Use whatever the manufacturer said. 10W-40 motor oil is the same anywhere in the country and is readily available.
   / Sir, what hydrualic fluid should I use? #4
I think you should be cautious enough to find and ask another Terex dealer, but the 10W oil does not sound all that far-fetched to me. A good detergent oil will keep your system clean and has good heat characteristics. I would also ask one of those Terex dealers where I might obtain an Operator's Manual so you don't have to guess at issues like this in the future.
Which is cheaper, a 5 gallon 10w oil or 5 gallon generic hydraulic fuild? :D
   / Sir, what hydrualic fluid should I use? #6
About the same price. My tractor called for strait 30W motor oil in the hydraulics. I did not like how slow it was in the winter so I switched over to a 20W hydro oil, AW64 or something like that.
Chris
Would 5W motor oil be okay for hydraulics and brakes?
   / Sir, what hydrualic fluid should I use? #8
Depending on where you live, whether the 10W - 40 motor oil would work. If that is what the dealer said, then I would use his advise. You can find that oil just about anywhere.
   / Sir, what hydrualic fluid should I use? #9
Yes you should use reg. 10w-40 motor oil for that because it is almost the best stuff you can get.
   / Sir, what hydrualic fluid should I use? #10
I would keep it all the same
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Zero Turn Mower (A59231)
Zero Turn Mower...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
