Sitrex Tedder Tine Spring Replacement
   / Sitrex Tedder Tine Spring Replacement #1
pbiebach
Vancouver Island, BC
Kubota L3800
I am trying to replace some brocken Tine Springs on a Sitrex HM-300 tedder, specifically the springs are ment to tilt up the tines when the tedder is not working to prevent damage to the tines.
My question is what the proper procedure is? does the whole assembly need to be taken appart or can they simply be poped on somehow? Special tools?
Thanks,
   / Sitrex Tedder Tine Spring Replacement #2
Are you replacing the big yellow tine/spring, or the smaller one that sits on the shaft?
If the smaller one, it looks like there is a rollpin that you would pop out to slide that shaft out.
Aaron Z
Yes I am trying to replace the small spring so removing the roll pin makes sense. would you usually just pull it out with pliers or punch it through with a punch and hammer?
   / Sitrex Tedder Tine Spring Replacement #4
Yes :D (it depends on how much of the pin there is to grab onto).
Yours, I would grab with a pair of visegrips then smack the visegrips with a hammer to get the pin out.
Aaron Z
Magnum 4000 Series Hot Water Pressure Washer (A47477)
Magnum 4000 Series...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2008 Dodge Ram 4x4 Crew Cab Pickup Truck (A55788)
2008 Dodge Ram 4x4...
JMR 600M Tree Boom (A53316)
JMR 600M Tree Boom...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
