Size of the fuel line out of the tank
   / Size of the fuel line out of the tank #1
clemsonfor
Super Member
Greenwood Co., SC
Yanmar YM2000
I have a YM2000 and when i was at the farm this last weekend i noticed that my fuel line from the tank to the filter is weeping fuel. Not really leaking but looks like its sweating deisel fuel as the tractor looks like a few drops have hit it under neath. Also looks like the oring in my filter houseing needs to be replace when i do the filter and line at the same time. the filter houseing looks just oily like fuel is getting out at a SUPER slow pace, i did not see a drip or anything but i know its leaking.
I am out in the middle of no where and just wanted to know so that next time i go there i can just have the line in hand when i go there.
   / Size of the fuel line out of the tank #2
MIne's been changed Along time ago. looks to be just 1/4". Fuel line. 2' should be plenty. May want to take some New Hose clamps also. Just sayin, Mine was done prior so I can't say forsure if you even need them. But it may be a good idea and not finding out that you do.:D
   / Size of the fuel line out of the tank #3
I believe the fuel line is 7mm ID (.27555"). You can sue if I am wrong. :D I would guess the 1/4" would work as Carey suggested. The 1500 parts manual says 340mm long (13.38"). Your 2000 could be a little longer. The fuel filter o-ring I believe is a Japanese standard p-42, 3.5mm cross section (.138"), 41.7mm ID (1.642").
   / Size of the fuel line out of the tank #4
I could see that my line was wet also. I'll catch it with my yearly Filter. I show the line is 5/16 and has been like that over 6yrs. since I owned it. Both a couple bucks at NAPA. It does look alittle big so I'm going to try to use 1/4". If not 5/16 is fine with me.
Its been a bit damp in the past but the last 2 months it really went to weeping i guess. Maybe the colder temps broke the rubber down and caused it to crack more??
I will take clamps and several feet of 1/4'' as thats what it looks like as well, maybe 5/16 not sure? I will see if my oring kit is standard or metric. If its standard i will try and see if one of my loggers has that size on the truck or stop by carquest and see if they have it.
   / Size of the fuel line out of the tank #6
Checked Carquest. They carry both 5/16"- 8m or 1/4"- 6.3m. Looks like I'll prob stay with 5/16. Definate if I was in your case out in nowere. The 1/4" maybe just enough to be to small. My luck I would break the old plastic Fuel Tank trying to force it on.:eek:
As cheap as fuel line is i will buy a couple feet of both. i use both on things. I think i have a mower that uses 5/16 and i have mowers and other things including outboards that use 1/4. I like to always have some fuel line onhand at my primary residence cause i never know when i will need it and i hate to make a special trip.
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
2016 Chevrolet Cruze Limited Sedan (A55758)
2016 Chevrolet...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
2019 ROCK LINE RS8-32 80" X 9' TILT TRAILER (A52706)
2019 ROCK LINE...
2001 International 4700 Bucket Truck, VIN # 1HTSCABNX1H380565 (A54865)
2001 International...
